Results 1 to 6 of 6
Thread: ke70 handbrake cables
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    hey guys, im nearing completion of a 4age into ke70 and i have pu a s series diff in it........the s seriesbrake cables were way too short and icould not usethem....... now i have installed the ke70org warner cables to the s series diff... theese cables are slightly too short.....they fit in the the little splitter part whereit goes from 1 into two cables but now i can get the drums on as it has pulled the shos out from the cables being a tight fit..... now i have checked the adjustment on the handbrake lever itself and it is adjusted alll the way back so there is no more slack to be had in the cables....... any ideas guys...... need something today.....
    cheers brendan
    MY JZX83 (clicky)
    Veteran anastasios's Avatar
    Taz
    Earlwood
    hmmmmmm we had this problem putting an s series into my brothers 71, but ive gone blank on how we fixed it...have u tried adjusting it on the lever? and making sure the lever is down?
    Ferny Grove
    I've just done this with a Tseries and KE70 handbrake cables. It should work in your situation as well.
    under the car there is 4 cable mounting points, 2 each side.
    Leave the rear 2 in place, undo the front 2 (10mm bolt with a c clip thing) don't reuse the C clip thing. Put the cable back in place and use the 10mm to hold the cble in the mount.
    Really needs a pic
    When you undo the middle mount the cables should want to pull forward and you'll see what i mean. The handbrake will function correctly using this method, even though it may look a little suss.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    ^^ correct
    wheelfriends.wordpress.com
    Ferny Grove
    cool, i wasn't sure if that was an accurate enough description
    Brendan
    NORTHSIDE YO
    cool as cheers 4 ya help gilly and cheers 4 da confirmation drift ke70... got it all in and done... cheers again
    MY JZX83 (clicky)
  1. Replies: 17
    Last Post: 30th September 2013, 09:26 AM
  2. handbrake cables for F-series
    By 1jz jakey in forum Technical - Questions
    Last Post: 31st July 2011, 08:38 PM
  3. handbrake cables
    By Fozz in forum Technical - Questions
    Last Post: 19th November 2009, 10:22 PM
