Results 1 to 10 of 19
Thread: trouble with falcon springs
    Ferny Grove
    Thumbs down
    I've had this in 3 seperate cars now
    using cut falcons, spring height anywhere between 200 up to 270mm (free) all held captive with short stroke shocks. sometimes when just installing them they will slip of the spring perch on the diff housing. other times they wait until i'm driving
    now heaps of people run them and have success, why do mine always fkn pop out?!?!?!
    at the moment they are actually installed upside down, as in the "flat" section is sitting on the diff and the pigtail up top. the weight of the car is squashing the pitail down to sit flat so it works, but its noisey (they creak)
    any ideas peoples??
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    no idea... i just dont bother fixing it, it happens to often... so i think one side of my car is like an inch shorter lol...
    cut rear springs ftl
    Senior Member DavisJD's Avatar
    Hold them in with some wire. May work, may not, worth a shot though.
    Ferny Grove
    hmmm so its more common than initially thought
    flip em Grant. ithought they were noisey, they aren't its just my diff touching my under diff exhaust as the springs are a bit high
    Veteran driftke70's Avatar
    Ryan
    Buderim
    yeah they never fell out of my car once or had any dramas, i installed them and took them out 8 months later without a single drama.
    wheelfriends.wordpress.com
    Veteran anastasios's Avatar
    Taz
    Earlwood
    yea weve got the au springs flipped with the flat sides on the diff mount, and the other ends up top
    Veteran deleta's Avatar
    Callum
    Queensland
    Wynnum
    yah i tryed holding them in with like 4 thick as zipties but they always brake and pop out, i always thought u needed adjustable panhard rod to make em not pop out.
    Brad
    Central coast
    i havnt had that problem with my 86, but what i did with my old car was drill a couple of 1/8 holes and thread a bit of fencing wire around the bottom of the spring so it sits flat. sounds dodgy, but doesnt hurt.
    Greg
    Coorparoo
    i run cut falcon springs, and 2 zipties either side, flat side of the spring on the diff.. never fallen out once.
    i made up a bracket that bolts through the hole in the perch on the diff... its a right angle thad just stops the pig tail bit dropping off...
    ftw
    cheers tim
  1. falcon springs?
    By biglettuce in forum Technical - Questions
    Last Post: 18th June 2010, 02:01 AM
  2. Falcon springs
    By rolla92 in forum Technical - Questions
    Last Post: 1st July 2009, 08:58 PM
  3. rear falcon springs, they are king springs.
    By NathanHann in forum Car Parts For Sale
    Last Post: 12th May 2008, 12:19 AM
  4. FS: falcon springs
    By slidn70 in forum Car Parts For Sale
    Last Post: 14th August 2007, 01:55 PM
  5. falcon springs
    By Cvet in forum Technical - Questions
    Last Post: 4th February 2007, 09:13 PM
