you can use that holley pump to fill you surge tank. then use another external pump fed by the surge tank to the engine.
vl seems to be the most commonly used external pump
hey guys, ok, i need a fuel pump and surge tank, i can get the surge tank made by dads mate no wories, but the fuel pump, ive been told by a few people what to get, theres a guy at work that has a holley low pressure pump with all the crap it needs to work, he dosent want much for it..will i be able to use that with my 4age? or does anybody else have one i can buy then use no wories?? thansk for ya time![]()
Double up on what Gilly said. I've spent so much time doing my fuel system it's not funny, between design and implimentation, and it should be all finished off this weekend. Since you're in Capalaba dude PM me and I can run through what the dealio is on my car if you're keen. Like, show you on the car and everything, since it's all naked at the moment. I'm running a 110L/h lifter pump to my surge tank which is Rocket Industry supplied, then have an external Walbro 255L/hr under EFI pressure to the rail. Piping is a bitch since there's a few ways you can go around it, but I'm certain I've got it down heaps good.
Can go through it with you the way I did it, and other ways that work but probably aren't recommended, pro's and con's of everything, probably cheaper ways of doing what I did as well.
i'm using the vl turbo pump too...using the feeder (lifter if you like) pump in the tank and the vl pump at the front in the engine bay together with my surge tank...that way i don't need to change to bigger fuel lines
Probably not, but same road, haha. Down the Capalaba end.
EDIT: Which domino's you talking bout? The Capalaba one, or the Birkdale one?
its in a street off mount cotton road, but its just over a creek from domino's. so are you on birkdale road?
