Results 1 to 10 of 13
Thread: Push button ignition start
    Senior Member Brenton 86's Avatar
    Brenton
    Talking
    Hi all,
    I managed to fuck both my key barrel and steering lock thingie this fine evening. Therefore im thinking it would be cheaper to just rig up button start instead of replacing my broken barrel. Just wondering if anyone has had any problem with this or cheap ebay kits.
    Looking at this one:
    Also as the key barrel seazed (therefore unable to take off the steering lock) i reefed it till it went bang, then i could turn the wheel like normal and move the car. Just wondering if anyone has also done this?? will it stay broken or lock up mid turn 6 at QR ?. The red plastic peice behind the wheel/bosskit know spins freely unlike a functioning one.
    Many thanks
    ADM 4AGZE SPRINTER
    JDM SR20DET TRUENO COUPE
    ae86s love since 2004
    Poh
    Bevo
    i would say you've broken steering lock
    YES it would lock pending if u only broke it one way (left or right)
    however if you broke it both ways it should be fine
    alot of people steal cars this way, the ghetto way
    u can easily make 1 up like the 1 on ebay..less than $30 probly and maybe not as cool or nice ..i used to have something like that..only problem was i fuckt the wiring and it drains my battery somehow so i switched back to the normal key stuff
    Brendo
    i have a button start WITH a battery isolation switch(on a key), best setup i think
    Oldschool Member
    Jul 2006
    yea prolly not good unless you have a isolator switch mainly because it pretty much gives criminals the stuff they need to steal your car.....
    where did u get this?
    Will
    make sure you dismantle the steering column and get rid of ALL of the bits of the steering lock, otherwise bits will pop out and lock the column at the most hilarious of times, like just before you need to steer around something to avoid crashing into it
    Brendo
    [/b][/quote]
    was in my race car when i bought it, just a box has a few switches like for thermo, ignition etc
    theres a place over here called richardsons pty ltd that we got a spare battery isolation switch key from, they are like a hardware/locksmiths sorta joint...
    Brenton
    Thanks for the replies guys
    Yea not getting an ebay one now, was this on as 86? I haven't checked the wires behind the barrel yet so just wondering if everything needed is there and easy enough to run to 2 seperate switches.
    Im hopeing ill be able to retain my immobiliser, so......flick the 'ON' switch, press the immobiliser then press the 'START' on a spring button. I truely i have no idea, so im hopeing someone can walk me through how they did theres.
    How would it drain the battery?? wouldn't an OFF/ON switch cut the power the same as the barrel?
    Also i was wondering how you strip all the steering lock and key shit off the steering coloum. Its obvious made to be resistant against being stripped and after looking at it today iv got no idea where to start
    Keep the help coming lads
    ADM 4AGZE SPRINTER
    You'll need a 3position switch for OFF - ACC - ON. Use this to connect 12V on one side to either nothing, ACC wire and IG wire respectively.
    Then you need a simple pushbutton for start. Connects 12V to STA when you push it. Probably best to make this connect IG to STA, just so you can't start it unless it's switched on.
    $5 worth of bits and an hour or so if you want to make it look nice. 5 minutes if not.
  1. Ignition Clicks, Car wont start when hot
    By djscheppy in forum Technical - Questions
    Last Post: 26th September 2012, 12:28 PM
  2. 4age retards ignition at start up sometimes
    By biggo in forum Technical - Questions
    Last Post: 21st October 2010, 02:19 AM
  3. push bikes
    By breno in forum Offtopic Discussions
    Last Post: 20th February 2009, 09:41 PM
  4. push button start and move barrel
    By Grantobius in forum Technical - Articles
    Last Post: 22nd June 2007, 11:20 PM
  5. GZE push rod
    By RcknAE86 in forum Technical - Questions
    Last Post: 11th June 2007, 11:13 AM
