Results 1 to 10 of 11
Thread: Getting an Engineer's certificate
    Hi all,
    Im thinking about converting my 4ac to a 4age soon..
    i was just wondering how hard is it to get an engineers certificate and approx how much does it cost?
    Not looking at getting a work shop to do it... how strict are the engineers and what are the chances they will fault it for stuff?
    Do I also need a blue slip?
    Thanks
    Ring your state's road authority and/or an engineer and ask all the above questions.
    Dave
    not sure what state your in, but if its QLD...department of transport is pretty much no help at all
    best bet is to ask around here (like your doin right now) and see where other people have gotten theirs done
    - Blaise Pascal
    Veteran driftke70's Avatar
    Ryan
    Buderim
    i got an mod plate for my conversion in about 10 minutes from a local engineer, cost 80 dollars, all he did was find out the old and new engine numbers, and ask the specs of the engines,
    ie 1.3 pushrod -> 1.6 dohc
    wheelfriends.wordpress.com
    If you are in qld, I dont think you need it plated, as there is no capacity increase.
    Veteran DRFTPG's Avatar
    ADAM
    some are easy some arnt so easy, we got my friends pulsar done for a 200kw engine and it passed no worries, the only thing we had to fix was the front bar because it was a lil loose
    Elite rthy's Avatar
    Leo
    Tulla
    what state are you in
    Im in Sydney, NSW.
    Sounds like its easy in other states tho
    Poh
    Bevo
    since your in sydney it depends which 4age your talking about, and also what you want to engineer
    if its just a 4age 16valve u dont need a engineers cert, only a blueslip
    20valve is a different story
    hope that helps
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    yeah all u need to do is call the rta and change the engine numbers....
    i had 16v un engineered and it passed blueslip in nsw after buying unreg from victoria no worries at all.... im now going 20v and ill just do the same as its already regod with 16v i can just change to the engine no. of the 20v as its still a 4ag no engineeres required
    MY JZX83 (clicky)
  1. engineer
    By Haul in forum Technical - Questions
    Last Post: 1st October 2006, 11:28 PM
  2. engineers certificate?
    By Gilly in forum Technical - Questions
    Last Post: 1st May 2006, 11:25 PM
