Results 1 to 10 of 10
Thread: Q about oil on plugs
    Mar 2005
    Just a quick question to determine how badly I should be worried about my engines health....
    took my ignition leads off today and noticed I had oil on the top of the plugs and on the/around the boots..
    couldnt be too good..
    any insight.......................?
    cheers
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    I changed my plugs the other day, found that Num. 2 and 3 plugs were covered in oil.
    Im not to stressed though because i know that my car has fucked valve seals which is the cause of the oil.
    Possibly you are having the same problem?
    Valve seal problems are also evident when you start the car up, it should blow smoke on startup but then it should be pretty tight once the car is running... Does your car dispay these symptoms as well?
    Valve seals arent a cause for great concern... though there is no such thing as a good problem either
    Mar 2005
    no never blows smoke... never had oil on the plugs like this before so its interesting...
    Joel
    Blackwood
    So you mean only in the spark plug wells? As in the electrode n shit on the inside of your engine was OK?
    If there is oil around the rubber boots that sit over the leads, then its likely you simply have an oil leak. Oil can't pass through the threads of the plugs from inside your engine! Sometimes the cam cover gaskets can leak oil?
    AE86 4AGE "Slowly but surely"
    Veteran driftism's Avatar
    Andrew
    Watsoia
    check to see if it's leaking from your cam cover seals into the middle of the head... cos it could run into the plug areas as they are the lowest point
    Mar 2005
    yeh it seems a bit strange, havent taken the plugs out as I dont have the socket on me.. The cam cover seals were replaced around a year ago but will have another sus anyhow..
    would having the oil level slightly over full and lots of thrashing have anything to do with it... ? ie: a pressure build up or something causing it to end up there somehow...?
    although said physically impossible..
    Dusty
    Lynbrook
    rocker cover gasket 100% sure
    Mar 2005
    sweet as, cheers for the help...
    Justin
    North-West Coast
    When i help out a friend at his shop, we continually had a 626 coming in with the rocker cover leaking oil.
    We put a new seal in it, and it kept leaking, so it might be a good idea to do what we did and put a dab of silicone in the corners and line the rest of the gasket with a thin line of gasket sealant (that red shiz) before putting the rocker cover back on.
    Hope that helps Niz
    Shane
    Tea Tree Gully
    maybe spilled oil when topping up??Ive done that before and it has setteled around the spark lead boots.
  1. S> New Trueno Badge, TRD oil filter & Iridium spark plugs
    By mr.smirfy in forum Car Parts For Sale
    Last Post: 21st December 2010, 11:07 PM
  2. oil on spark plugs
    By Johnny_08 in forum Technical - Questions
    Last Post: 5th July 2007, 07:52 PM
  3. omori oil filter relocation kit with oil temp and pres guages
    By ae86 slide in forum Car Parts For Sale
    Last Post: 21st March 2007, 07:04 PM
  4. Where to buy injector plugs and important sensor plugs
    By HYPNTK in forum General Topics (No Technical Questions)
    Last Post: 14th March 2007, 02:39 PM
