Results 1 to 10 of 13
Thread: brake failure
    went for a mountain run the other day.. was using brakes pretty heavily, so wen i was towards the end of the mountain the last couple of turns, my brakes started not to work that well.. i was pretty determined it was brake fade.. so i waited for it to cool down. it was still the same. so i had to crawl back home with shitty brakes.
    my brake fluid is still full so im not leaking anything.. my pads are still meaty..
    wen i started my car in the morning to reverse out of my drive way, i pumped the brakes to get the fluid in there and then held the brakes down, i started my engine and then the brake pedal just went down (felt like all the fluid just leaked out of sumthing)
    any help would be appreciated
    Jonathan
    For whatever reason, you have air in your brake fluid. You need to bleed the brakes, and by the sounds of it you should change your brake fluid also.
    If that does not fix things, you need new seals and a hone in your master cylinder.
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    Also, check all of your hoses in order to make sure that there is no perished/ cracked hoses as this could be the cause.
    Elite rthy's Avatar
    Leo
    Tulla
    it does sound like the master cylender has given up to me
    hey which area where you hooning around anyway? on mount dandenong toorist rd?
    how Hot do you think your brakes got?
    not hot enough to boil the fluid?
    i know its a long shot
    that should be normal isnt it?
    Sameul
    Bulleen
    I think he means down to the floor... so no - not normal... Pedal sinking a little bit when the car starts can be normal.
    Could be from boiling your brake fluid. See suggestions given above.
    Site Supporter Javal's Avatar
    Josho
    If your brakes are pumping up then you have air in the lines.
    BUT because the pedal goes away almost completley when the motor is started, then it is something to do with your brake booster.
    From the sounds of it it's not creating vacuum anymore, could be a busted seal, hose has come off, etc.
    Javal.
    went to a ns.com cruise with my mate.. was the only 86 there.. tho a "toyota" soarer was leading the pack..
    yea i didnt know where is was but i recognise mount dandy wen i got there.. was pretty please with my car with the new coilovers in. the lil 86 stuck to the road with ease watching a 180sx in front with tein coilovers all round understeer. and a skyline not able to keep up with me except for the straights.
    i thought the fluid was leaking but wasnt and check the if it was boiling but also wasnt.
  1. Fuel pump failure
    By 70rolla in forum Technical - Questions
    Last Post: 17th November 2011, 05:03 PM
  2. keyway failure on a 20v?
    By Sam-Q in forum Technical - Questions
    Last Post: 24th January 2009, 08:35 AM
  3. BRAKE FAILURE BOX
    By Selk in forum Cars or Parts Wanted
    Last Post: 8th July 2008, 08:06 PM
  4. backlash, prolonging failure
    By seek in forum Technical - Questions
    Last Post: 28th November 2007, 09:15 PM
