never mind....theres no chance in hell it will fit
just noticed clutch fan is fcucked and i have a vn thermo fan laying around, is it a good idea to move the sloppy old clutch fan and fit the vn thermo fan in instead ??? ill just have it wired to a switch till i can get it wired to relays . would this be an upgrade or not , dave
wiring to a switch SHOULD include a relay - you don't want the power for the fan running through some crappy switch in the dashboard setting everything alight.
don't rely on yourself turning the fan on and off or you'll forget and cook it. at least make it always on while the ignition is on.
there should be some switch you can pilfer from another car that goes to ground when the water temp gets to a certain degrees.
i'm sure there's plenty of 4ac fan clutches floating around on an ae86 forum. i think i threw mine in the bin.
yeah i got one spare (clutch fan)
whats a clutch fan??
is it like a fluid coupling fan or different??
a thermo fan is an upgrade if you can figure out a way of turning it on and off with rising/falling temperature.
i have a supercheap thermofan in my car, and i made a little temperature switch to control it.
as devolutio said you can prolly get a controller of some sort from a FWD car
but i would just get another clutch fan and stick it back on, saves all the effort for not much gain.
- Blaise Pascal
