Results 1 to 8 of 8
Thread: 100kw smallport rebuild
    I picked up a 100kw out of an ae92 for free....
    Was running but had a suspected BHG.
    I have started stripping engine and will have the head sent off to a head shop for cleaning and servincing as need be....
    Block will be cleaned as best as possible with whatever i have access to. I only intend to use this as a daily driver but may decide to use gze pistons for a low boost application. At the least, new rings, big end and main bearings, and all gaskets/seals will be replaced.
    I hope to do most of the work myself (first time rebuilding engine) and will be doing alot of research along the way. I will appreciate any info/advice from anyone who has any experience in rebuilding these engines. I have plenty of tools and what i dont own, i will either buy or have access to via friends.
    Which brands of parts should i use?
    Which shops in Sydney should i use to to do any required honing/machining work?
    Anyone feel like giving me a hand? haha... no harm in asking
    At the end of the day, i want to be using as little as possible as my main project (v12 supra) is higher on my cash allocation table.
    Veteran Wally's Avatar
    will be keeping an eye on this also...
    4AGE 16V
    Mar 2005
    exactly what Im about to do also.. over a few months.. a little work though, cant really give any pointers as its my 1st time doing a rebuild also... should be fun..
    Veteran slide86's Avatar
    Huw
    Hills
    i used ACL and genuine toyota parts on my GZE rebuild. had no dramas at all.
    i also used a HKS headgasket, ARP studs through out the entire engine and a genuine oil pump (brand new).
    can you give prices off the top of your head???
    Again, i want to use as little as possible....
    Huw
    Hills
    it wasnt cheap. and i got discount cause im in the industry. ARP studs was over 400 alone.
    gasket set was a few hundred, 250 i think. i would use an ACL gasket set tho. and ACL bearings
    Terry
    Ipswich
    for prices see . all parts usually in stock
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    I machine motors for a living. Though at my new job it's a hell of a lot harder to do motors for my friends / associates then it was at my old job..
  1. Smallport 100kw motor
    By joeschmo_57 in forum Cars or Parts Wanted
    Last Post: 13th November 2009, 05:44 PM
  2. 100kw motor fs $200 suit rebuild
    By 4000gt in forum Car Parts For Sale
    Last Post: 7th July 2007, 04:32 AM
  3. 100kw smallport dizzy problem
    By slippry in forum Technical - Questions
    Last Post: 23rd March 2007, 01:04 PM
  4. Smallport rebuild
    By unit101 in forum Technical - Questions
    Last Post: 6th March 2007, 06:27 PM
  5. 100kw or GZE engine suit rebuild or just head
    By terryo in forum Cars or Parts Wanted
    Last Post: 11th February 2007, 11:49 AM
