Results 1 to 5 of 5
Thread: Engine rebuild
    Hey guys
    My smallport rebuild is coming along nicely- I'm just a bit stumped on what cams will best suit my engine. Im using acl race series pistons(standard size),acl race series bearings and gaskets and seals. The head is getting rebuilt to standard specs with a mild cleanup of the ports (removving casting marks and smoothing sharp edges) and i will be running stainless tuned length extractors with a straight through 2.25 exhaust. I plan on retaining the standard computer for a while, so i was wondering what size cams (eg duration/lift) I should use that will best suit this application. Anyone who has done this before, I would like to know your thoughts, and any help is much appreciated.
    Rohan
    Will
    for a standard engine, run standard cams. no point buying aftermarket cams twice, wait till you get a programmable ECU and get some 272s or something.
    Oh -ok- I was just told that if you have a free flowing exhaust, and ported head, you should change cams to maximise the new rate of airflow.
    parrot
    search
    Elite rthy's Avatar
    Leo
    Tulla
    a flew blowing exhaust with a ported head works well with a standard cam
    30kw club
  1. engine rebuild question
    By SR_andy in forum Technical - Questions
    Last Post: 26th April 2009, 11:07 AM
  2. 4AGZE Engine Rebuild
    By LiTTLe_DRaGoN_HuNTeR in forum Technical - Questions
    Last Post: 8th March 2008, 03:53 PM
  3. engine rebuild
    By psi_72 in forum Technical - Questions
    Last Post: 21st September 2006, 07:44 PM
  4. Cost of engine rebuild?
    By Skin in forum Technical - Questions
    Last Post: 25th March 2006, 04:20 PM
  5. Engine Rebuild
    By Shahzan in forum Technical - Questions
    Last Post: 4th December 2005, 12:55 PM
