Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: bigport 4age problem
    Happy I could help
    Now either setup a relay as intended by factory or cross over the orange/black coil wire to the BF wire (this is how ae82 4age works)
    What loom do you have, FWD AE82 modified or JDM AE86 ?
    Senior Member superbmobile's Avatar
    Justin
    Happy Valley
    yeah cheers again. yeah im running a jdm 86 loom.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Sounds like you have a serious vacuum leak.
    Did you take the manifold off the motor during the swap process?
    If you did, what gaskets did you use when you put it back together?
    Oversized 86
    no your not...
    its a modified ae82 loom...
    If that's the case, something has been modified in the loom, or the fuse is blown on the loom for the EFI. One of those little dangler things hanging of the loom over the firewall. the biggest one should have a fuse.
    That's if someone didn't cut it off.
  1. Replies: 6
    Last Post: 15th October 2012, 06:02 PM
  2. bigport 4age,20v 4age,longchamp,rwd 4age parts,everything.
    By Aquaae71 in forum Car Parts For Sale
    Last Post: 22nd March 2012, 04:24 PM
  3. 4age problem
    By ghetto ke in forum Technical - Questions
    Last Post: 26th October 2009, 12:10 AM
  4. 4age problem
    By Andor in forum Technical - Questions
    Last Post: 19th September 2008, 04:03 PM
  5. 4age problem ?
    By w84me in forum Technical - Questions
    Last Post: 22nd October 2007, 07:33 PM
