Check if your fuel pump is staying on. Maybe it's running only while the key is in the start position, then cuts out once you let go, giving you only a few seconds of pressure.
so basically the motor will run for around two to three seconds at high idle and then stall, ive check various plugs and relays etc and it is getting fuel and spark. any help would be appreciated cheers.
the car is running the infamous "raging inferno" fuel setup...
no COR..
yeah as soon as the throttle is touched it will stall.
This is happening with my car, but mine stays on for a while. i.e. it idles but only just. Im hoping the new MAP sensor I got for it will fix it as the old one seemed to be stuffed.
yeah the map sensor is still in working order ive tried it on another motor so it rules that out.
Have you just installed this into your car ? Have you had a 4AGE before ? Has this been running in this car fine before with no problems and this has just come around ?
Let us know and we might be able to give you a more direct answer.
In the mean time go to your ECU. Check that the BF pinout on the 10pin plug to the LEFT.
Check that this has 12v when the key is turned to ON (Ign ON). If it doesn't, temporarly add a wire from BF to B+. Try to start the car again and see what happens.
Ecu pinouts below.
yeah the 4age was just installed came out of a previous running car. Yeah mate looks like it never had 12v i tried the wire and it worked cheers.
