Results 1 to 10 of 11
Thread: Suspension issues - When and what to get ?
    Hi all,
    I bought my ADM sprinter with Lovell Super low springs on all corners in it already (put in by previous owner) and not sure what sort shocks.
    But lately i noticed the ride is getting bumpy and handling a bit worse.
    I did the push down test on each corner and it dips like a bastard. Also it bounces a few times before stopping.
    What will I need to replace?
    Is it only the shocks that I need replaced? Springs dont go out that quickly do they?
    What are some decent shocks I can get that arent expensive that will go with my Lovell springs.
    Want a good ride that will handle well. Also hopinh to learn to drift one day. please recommend.
    Are Pedders any good to go to?
    Are shocks something that you only buy brand new or are 2nd hand okay too?
    And are lovel super low springs decent sort?
    thanks for any advice.
    Veteran Konakid's Avatar
    Henry
    Eastern
    Shocks
    Yes
    KYB Excel G's from AJPS
    Buy new
    get them to install you products, dont buy theirs
    decent for looking hektic, but the spring rates would be too soft for any serious street or track use
    Thanks for the reply.
    I was told that only my rears need changing soon.
    Reckon I should change all 4 with KYB Excel Gs or can Iget away with just doing the rears an notice an improvement in handling?
    Do the Excel G's increase the ride height at all? I like mine atm, nice and low
    Also how much do places charge for fitting? are Pedders cheap?
    Henry
    Eastern
    I have recently only replaced my rears and while it is a noticable improvement it only highlights the stock front shocks crapness so it almost feels worse than stock. Definately worth replacing all round for a much more balanced and nicer ride which is what im currently saving for.
    It shouldnt increase your ride height as springs determine ride height, not your shocks. However given that the excel g's are stiffer it could raise it very slightly but im unsure. If the car is quite low i would say go for the short stroke version front and rear.
    Not sure about fitting charges, probably around the 150 mark at most. Don't know about pedders, just go to any suspension joint and get quotes.
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    The excels should be short stroke, so the hight issue won't be a problem. Replacing all round would be the way to go, only replacing the rears would cause a problem I feel, and possibly dangerous on the street, let alone the track (if applicable). Not sure about fitting charges at Pedders, mine were fitted by the previous owner at a friends garage (I was there too, cost only a couple of 4 packs of V )
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
    Thanks for the input guys..
    guess Ill go all 4's...
    Anyone here want to put them in for me in exchange for some booozee ?
    Site Supporter Javal's Avatar
    Josho
    Location?
    Veteran slide86's Avatar
    Huw
    Hills
    buy the shocks from AJPS and get them fitted there also, thats if you are in SA.
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    Put them in yourself. Its dead easy. All you need is a big shifter/pipe wrench, sockets, ratchet spanners and a jack.
    Save money. Buy more suspension.
  1. Reverting from S13 suspension => AE86 suspension
    By crunchie in forum Technical - Questions
    Last Post: 3rd January 2011, 11:31 PM
  2. front suspension issues
    By fantapants in forum Technical - Questions
    Last Post: 19th June 2010, 08:33 PM
  3. Sr20 Issues
    By bigm in forum Technical - Questions
    Last Post: 17th April 2010, 12:28 AM
  4. Clutch issues
    By sprint86 in forum Technical - Questions
    Last Post: 20th August 2009, 09:04 PM
  5. Suspension Issues - How to test?
    By li21 in forum Technical - Questions
    Last Post: 5th July 2007, 11:25 AM
