Results 1 to 3 of 3
Thread: Cam gear help
    Veteran driftke70's Avatar
    Ryan
    Buderim
    Just purchased some hks cam gears that will be going onto the keto
    a jdm bigport with 7 rib bottom end and trd cams. Just wondering anyone could give me a guide on the best way to set them up and what these setups control, ie revs power response whether they effect reliability etc
    thanks in advance
    beally
    wheelfriends.wordpress.com
    Jonathan
    Lots of guides on the internet. Do a general search. The procedure will be the same for most twincam engines.
    Tools you need:
    dial gauge. Idealy with a long flexible holder on a magnetic stand. Its also good to have a custom dial gauge with a curved pointer that clears the camshaft and gets a good angle touching the bucket.
    degree wheel
    sockets for spark plugs and crank pulley.
    allen keys
    calculator
    pen and paper
    there is a way to find TDC more acuarately than the plastic marks. You need a bolt screwed down the spark plug hole...
    start taking your readings only after 0.040" or 1mm movement of the valve. This is more accurate that noticing when the valve starts to measure.
    You are most interested in where the lobe centre is. You measure this best by knowing when the valve opens and closes (or after 1mm movement). Lobe centre is in the middle of this.
    For inlet:
    BTDC + 180 + ABDC = duration @ 1mm
    (duration / 2) - BTDC = lobe centre position
    A normal engine will have the lobe centre at about 110 deg both ex and in. For a hot NA motor you want lobe centres closer to 100 degrees.
    A setting at 110 degrees will give a smoother idle, even with "lumpy" cams. A setting at 100 degrees gives more valve overlap, it should breath and give more power in the high rpm range, but will have a lumpy idle.
    Ryan
    Buderim
    cheers for the info
  1. cam gear cover
    By VTAZ! in forum Cars or Parts Wanted
    Last Post: 17th June 2012, 03:20 PM
  2. WTB: 16V Cam Gear or 20V Exhaust Cam Gear
    By Oly AE86 in forum Cars or Parts Wanted
    Last Post: 7th October 2010, 03:26 PM
  3. cam gear cover
    By riceburner in forum Cars or Parts Wanted
    Last Post: 24th October 2009, 09:54 PM
  4. cam gear cover
    By callum1 in forum Technical - Questions
    Last Post: 3rd December 2007, 07:24 PM
  5. cam gear covers
    By Rich_86 in forum Cars or Parts Wanted
    Last Post: 11th October 2007, 04:30 PM
