Results 1 to 9 of 9
Thread: Carbie or efi 4ag
    Senior Member eightsixboy's Avatar
    Paul
    East
    Hey guyz, I'm doing a 4age conversion soon and was thinking of going the carbie route just casue it should be cheaper to buy a motor without the injectors, map sensor, inlet manifold etc. i know carbies are expensive to buy but also know that i will get about a 15 hp gain just from putting them on. besides the efi management systems are real expensive from what i can tell. Plus i dont mind having to tune the carbies every week or so, love working on my car and keeping it in good mechanical condition
    Thats my thoughts anyway,
    Cheers.
    Dave
    heres my thinking--> (for a bigport, and prices are just estimates from what ive seen)
    stock 4age - $500 (should be able to get one with most of the stuff you need for that, injectors alternator, starter etc) from the wreckers or forums
    loom/ecu maybe $200-300 maybe? (just stock ecu)
    jdm/cut and shut inlet manifold - $200
    now for carbies,
    engine - 500$
    carbies - 500$
    and then whatever you need to do to the ignition system (do those deloratos (spell) carbies, have a spot for vac advance, and does it work on normal dizzy?) may have to get dizzy re mapped or something, im not up on this kind of thing sorry
    you will still need decent-ish fuel system for both (ie decent efi pump, and most likely a surge tank)
    so i dunno, i guess its a much of a much-ness really.
    if you know what your doin with carbies there can be great gains had from then, i personally would prefer to go efi, just cause its easy to just stick it all in.
    carbies have the awesome induction roar, so thats a pretty big incentive to go carbies
    - Blaise Pascal
    Elite rthy's Avatar
    Leo
    Tulla
    i would use efi for a daily
    carby is awesome but pretty much useless with out some work done to the engine
    Paul
    East
    Basicaaly was thinking that it would be way easier to set up, from what i can tell as long as I have a manifold for the carbies its just a matter of bolting them on, fuel supply and throttle linkage. Sure I will have to spend alot of time tuning but I don't mind that. I got the dizzy situation sorted out. I was hoping to be able to get the engiine super cheap cause i would just be buying basically the head, block, exhaust manifold and thats it, don't need the injectors, intake manifold, map senors and ecu.
    Anywayz depends if I can get the aprts seperatly or not. i'm only a 2nd year mech and not to confident with the ecu wiring even though it would be easyish from what i've heard. Plus there the issue of no engine light on the dash, and what happens if any of the electrics stuff up,want to keep it as simple as possible for now.
    Seth
    Carbies are good. That way no cpu. So when you want to chuck in big cams you don't have to get a after-market cpu. Which costs quite allot fitted and tuned. Carbies for the do it your self. And being a mechanic you should have no trouble tuning them once you you get the hang of it. tuned well you will nearly have as much power as quad throttles. Also make sure you get 45-mm throat not 40-mm.
    Paul
    East
    45mm not 40mm ok cool. yeah was thinking bout a pair of solex's.
    Elite rthy's Avatar
    Leo
    Tulla
    45mm? fark thats like 800 a pair xD
    40mm are like 200 apair 2ndhand
    40mm solex are common on those 2tg or 18r
    Senior Member Brenton 86's Avatar
    Brenton
    Search
    ADM 4AGZE SPRINTER
    JDM SR20DET TRUENO COUPE
    ae86s love since 2004
    Seth
    na, he'll find some second hand.
  1. efi too carbie in a hachi
    By dehney in forum Technical - Questions
    Last Post: 12th November 2011, 06:55 PM
  2. open carbie
    Last Post: 5th December 2009, 01:01 AM
  3. 4AG Carbie celica movie
    By flamingheads in forum General Topics (No Technical Questions)
    Last Post: 13th March 2006, 07:42 PM
  4. Carbie 4AG
    By dreny in forum Technical - Questions
    Last Post: 7th December 2005, 03:10 PM
  5. Carbie 4AG
    By xsoarerx in forum General Topics (No Technical Questions)
    Last Post: 1st January 1970, 11:00 AM
