Results 11 to 20 of 21
Thread: 2ZZ-GE
  1. #11
    Anthony
    I finally tracked down a Japanese built 2ZZ for the right price (as opposed to locally delivered South African built ones for $1000 plus that have dubious reliability).
    I've started looking into getting it into an 86 shell I have here at work.
    It doesn't look too hard, some usual issues, some new ones. The water system is a headache but at least its coil and igniter on plug with direct crank triggering so no ignition firewall probs.
    There are no mount bosses on the LHS but if I delete the A/C then that gives me 3-4 M8 bosses to play with which may be enough. I've checked the lift bolts and theyre unbroken - yay. (a common problem on these motors).
    As for transmission im just grafting a JDM T50 on to it (with an aussie bell housing as the inlet is other side ) The clutch is a 212mm with small spline just like a smallport/20V.
    The higher profile cam looks huge and duration is up on it too. The inlet cam has infinite VVT, like both cams on the Beams 3S in my coupe. I'll be using adaptronic engine management of course as it runs the dual VVT on the beams no problems and the variable lift is simply an RPM dependent switch with oil pressure and engine temp interlocks (easy to implement).
    Anyway, some pics to follow soon in a build up thread. I'm trying to do it in a repeatable way (ie, feasiible for a customer to afford to do it again).
  2. #12
    Oldschool Member
    Feb 2006
    Jeezus, hate to think of the cost.... Sierra boxes are mega expensive and far from bulletproof even in your 120hp modded 1.6 Ford kent sort of applications, cannot see it being a good thing in the long run.
  3. #13
    so u reckon it would all work anthony? and all up costs would be good to note too
  4. #14
    Sounds like a kool conversion would be expensive but its worth it 4 LIFT
  5. #15
    Anthony
    just after a bit of info on the varible cam setup with these engines (setting up an autronic on a turbo sportivo)
    having trouble getting info on how much advance/ retard ?? & type of signal to drive it
    any help would be very helpful thanks Drew
  6. #16
    riojin
    so how much was the jap 2zz?
    repeatable way? where do you work? if you do it id love to get it done to my ae86.
  7. #17
    haado gei
    He works at kaizen garage, qld. the conversion can be done to your ae86 for 8500 drive in, drive out if my memory is still working.
  8. #18
    riojin
    id have to keep the ae86 for atleast another 3 years if I were to spend that on a conversion. but it is tempting. guess ill start saving and see what happens
  9. #19
    Seth
    I bought a semi-dead 2zz about a year ago.....still not sure what to do with it
  10. #20
    riojin
    just watch these....
  1. My Turbo 2ZZ Powered 2003 Sportivo - 248fwkw
    By xoom in forum Other Toyotas
    Last Post: 12th March 2017, 12:49 PM
  2. 2jz-ge??
    By ThatsHowWeRoll in forum Technical - Questions
    Last Post: 18th April 2009, 11:03 PM
  3. Ge sigma arms
    By dog89 in forum Technical - Questions
    Last Post: 23rd September 2008, 03:54 PM
  4. FS- 2zz individual coils
    By 86 garage in forum Car Parts For Sale
    Last Post: 1st January 2008, 05:00 PM
  5. 2ZZ-GE into ae86 ??
    By tin can in forum General Topics (No Technical Questions)
    Last Post: 28th July 2006, 02:04 PM
