hey all,
what adapter do you use when you install an aftermaket fpr??
just net searching, i cant find 1 for a 4age from malpassi or sard, do they have them for 4age?
what have you guys used??
thanks
hey all,
thanks
Why would you even need one, a decent ecu and fuel pump can handle any fuel demand you will need.
fuel pressure regulator as far i can see is only a bandaid repair for a bigger problem.
But if that isnt a viable option for you then just take off the vacum line to the regulator to increse your pressure. But i dont really recomend it.
Insert witty comment here....
oh ok thanks for your help!
yeah i am running a haltech ecu, wolbro pump and 580cc injectors so i should ok on standard reg??
thanks
If its tuned right and by the right person you should be fine.
Your ecu, pump and injectors will do the trick, actually its some pretty high end stuff, not like you gunning for 800hp is it.
Look at JEM's 4agte has made 270rwkw on stock for pressure regulator.
hehe, he's the man!
well my tuner anyway...![]()
JEM FTW!!!!
If adam says you need an adjustable fuel regulator then buy one, but if it isnt needed then why bother.
Unless its for the bling bling points![]()
nope, neither, i was just assuming....
so yeah should be right on the standered regulator, thanks
