Results 1 to 10 of 10
Thread: 20V silvertop head on a rwd 4AGE 16V
    May 2007
    Just wondering whats involved with this conversion? I got a call about a 20V silvertop head, $200. How difficult is this to fit to my 4AGE in my sprinter? What additional parts are involved?
    Also... putting 20V quad throttle bodies onto my 16V motor..... need some info aswell.
    cheers,
    Poh
    Bevo
    not sure if they will fit
    however if its the other way round
    20valve bottom end with 16valve head it works, plus u get a more torque throughout the rev band
    parrot
    Doesn't fit, think of the number of valves vs number of fly cuts in pistons.
    Veteran deleta's Avatar
    Callum
    Queensland
    Wynnum
    U can put a 20v head on a 16v block u just gotta put the 20v pistions on the rods in the 16v block
    parrot
    At which point you just put the whole 20 valve engine in.
    Jonathan
    Additional parts:
    20v ECU
    20v harness or plugs to make your harness
    hole in firewall or twincoil conversion
    custom bits for water outlets
    Elite rthy's Avatar
    Leo
    Tulla
    the pistons dont need to be changed, just becomes an interference engine. As the guys have said its not really worth it.
    As for putting quads on your engine you need to either buy the manifold adapter or make one yourself.
    whats in a 20v bottom end? same as 100kw?
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Pistons are different. So are the rods as far as I know.
    Jonathan
    For the same month and year, the 20v 4A-GE has the same crank and rods and bearings as a 4A-GZE. The rods were updated a few times but the 4A-GE and 4A-GZE both got the same. Bearings are the same as in 4A-FE. Oil squirters same in both engines.
    The AE101 4A-GZE has the old style AE92/AE86 type sump and baffle and matching block. The AE101 20 valve has a bit cut out of the sump and the matching block. The only reason for this I know of is to clear the transfer case on some 4WD models, just like the AE95 sump/block.
  1. Wtb 4age 20v silvertop rwd extractors for ae86
    By lui90 in forum Cars or Parts Wanted
    Last Post: 12th December 2012, 01:57 AM
  2. 20V 4AGE Silvertop RWD setup
    By willio in forum Car Parts For Sale
    Last Post: 13th January 2012, 10:04 AM
  3. Replies: 0
    Last Post: 19th May 2011, 09:40 PM
  4. Replies: 12
    Last Post: 15th January 2011, 07:15 PM
  5. RWD 4age Silvertop 20v Race Engine + W58
    By ke25 racer in forum Car Parts For Sale
    Last Post: 12th August 2008, 08:28 AM
