If you gus are running a gze that was origionaly running a map sensored ecu (8.9:1 compression ratio) i have made a safe 170rwkw at 16psi and the engine took a thrashing UNTILL boost spike from dogee external wastegate to 19or 20psi first melting 3 pistons then finally cracking block and blowing headgasket.
my engine was running stock everything enginewise except for rwdjdm intake manifold. Im just giving a warning for all you guys looking for big power from stock gze's if you are running high boost make sure you are running the low comp AFM gze (8:1 compression ratio) as in my unknowledgeable days i smashed a good GZE. cheers.
