Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: JDM GTV/GT-Apex Steering rack
    Ken
    Spearwood
    I've heard that the GTV and GT-Apex steering racks are supposedly a quicker rack than the ADM one?
    Is this true and if so, would it act just like the Quaife Quick rack and not allow the use of Powersteering Arms AND lock spacers? Because of the limited amount of teeth.
    Thanks in advance,
    Ken
    Jonathan
    EDIT: sorry
    The manual steering rack and pinion is the same on most AE86/AE85. LHD is different of course.
    The pinion is the same for all manual steering, except for LHD.
    But the GTV has a different rack, different part #. But it has the same pinion. Not sure how its different, I don't have one to check. Please send me a GTV rack.
    The GTV tie rod ends also have a different part number. But the rack ends are the same (which are also same as early P/S ones.)
    Veteran Wally's Avatar
    my steering is fucking heavy as :/
    dunno whats going on there
    Trueno Apex (Zenki)
    4AGE 16V
    Poh
    Bevo
    maybe a wheel alignment?
    Jan 2007
    yeh mate proberly up for a wheel alignment just like me, mines pretty heavy ATM!plus massive understeer in the wet (wheel alignment being out caused a bald inside wall of front tyre)=FTL...................
    Dan.
    yeah i thought it may have been this, plus the tyres are not in the best condition, plus i bet the chamber is pretty all over the shop from the chamber adjusters.... getting new ones on Wednesday hopefully.
    Thanks guys.
    4AGE 16V
    Jonathan
    You have power steering, make sure the pump is working.
    How can i check the pump is working?
    4AGE 16V
    Jonathan
    Connect a powersteering pressure gauge, the special one that you don't have. You should have 65 kg/cm^2 with the steering wheel on full lock.
    It maybe easier for you to take the powersteering belt off, and see if the steering feels the same.
    More info from the net:
    GTV is the only 86 with the Quick Steering Rack (Like Jonny said)
    Steering rack changed slightly, slightly smaller, with larger bushings to compensate when mounting
    Quick Steering Ratio (Lock-to-Lock : 3.0 Turns)
  1. fitting GTV bumper to GT Apex body
    By subaer in forum Technical - Questions
    Last Post: 19th June 2009, 06:33 PM
  2. ==||> JDM AE86 Levin GT-APEX <||==
    By monkae86 in forum Cars for Sale (Toyota Only)
    Last Post: 1st June 2008, 04:07 PM
  3. GT-Apex & GTV
    By ae86gt-apex in forum General Topics (No Technical Questions)
    Last Post: 2nd June 2007, 09:43 AM
  4. gtv gt apex?
    By STOCTI in forum General Topics (No Technical Questions)
    Last Post: 30th October 2006, 01:32 PM
