Results 1 to 10 of 15
Thread: bigport VS bigport :S
    Senior Member JDM-086's Avatar
    Dario
    Melb
    whats the difference between an ADM bigport short motor and a JDM bigport short motor.....i no 1 is supposed to be 88kw and one is 96kw but really what other differences are there internally..
    4age 16v btw
    Eddie
    No difference at all, aside from the intake/cooling setup. The additional KWs come from the ECU.
    Eddie.
    Dario
    Melb
    so theoretically if you have a JDM RWD 4age 16v bigport setup in your 86 you could replace that short motor with an aussie FWD bigport short motor and itd be exactly the same?? no power diff either??
    Member tristybomb's Avatar
    Tristan
    Jap use i higer octain fuel than aus and there ecu's are tuned to suit it from factory hence more power
    all engines wil be different some how e.g how theyve been looked after, k's. A thrashed jdm bigport wont have as much power than a low k's well maintained aus fwd bigport.
    Dario
    Melb
    but my above example should work fine if say they r both same condition, just swapping the short motor using all the JDM shit
    Ferny Grove
    yes, i was going to say that on msn put all your RWD gear on an aus spec AE82 bigport.
    Dario
    Melb
    lol or other way round...rip my jdm engine out and put in an aussie 1
    Tristan
    Step one rip out jdm engine pull off intake manni ecu wiring and replace on to aus spec bigport.
    Dario
    Melb
    booyah thanx heaps. i was thinking bout replacing my engine and i was tryna find a JDM bigport as thats what i had. i thought maybe they were different as the hp is diff. but as all you guys stated they are the same the only reason for the power difference is the cooling and ecu differences the JDM n ADM bigport have.
    cheers thanx all
    ive driven with a jdm ecu and an adm ecu and found the jdm to less economic no more power
  1. Replies: 6
    Last Post: 15th October 2012, 06:02 PM
  2. Bigport Head/ Bigport Engine Briz
    By toyotakraze in forum Cars or Parts Wanted
    Last Post: 18th January 2011, 01:28 PM
  3. Bigport???
    By drftr86 in forum Technical - Questions
    Last Post: 10th October 2007, 01:13 PM
  4. Replies: 6
    Last Post: 22nd May 2007, 11:37 PM
  5. Differences between n/a bigport head and gze bigport head
    By Course_Out in forum Technical - Questions
    Last Post: 5th April 2006, 01:52 PM
