Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Group A Sprinter for sale...
    Mar 2010
    Rory
    Wonder how much he's asking....be a good project....
    R
    Mar 2007
    that wud be a sweet buy just wish they had more pics
    Seth
    I email him and he sent some pic and current restoration details.[attachment=15534:attachment] [attachment=15535:attachment] [attachment=15536:attachment] [attachment=15537:attachment] [attachment=15538:attachment]
    Toyota AE86 Sprinter Group A. VIN# AE86-16204
    History
    According to Bob Holden it was built originally as a GpA rally car, possibly for Brian Hilton of Mossman NSW, and probably in mid 1983. It was purchased by Bob Holden Motors and converted to circuit racing. Bob campaigned it in ATCC 1985-92 taking a class win at Bathurst in 1987. There were multiple drivers over these years with Bob leasing/renting it to whoever came along. It was sold to Adrian Brooke in 1990 who extensively refurbished it with the help of Peter Helihen, a well-known local race mechanic. Its last major circuit event was 1993 Bathurst, with the major sponsor being 4KQ. At that time, computer systems were very expensive so they removed the computer and it supposedly became the last carburetor car to run at Bathurst. Subsequently used for limited club-level racing, then for “rally experience". At some time during this later phase the front AP brakes, webers and bag tank were discarded and a Motec computer fitted to control the refitted Toyota injection.
    Toyota Sprinters
    This model of car was raced here by Toyota Team Australia (TTA), Bob Holden Motors and multiple privateers. Some retained the local model name of “sprinter", while others used “Levin", the performance Japanese model, which came standard with the performance 4AG twin cam engine. TTA also raced a few coupes, which had a different body but identical mechanics. Locally sold Sprinters were typically upgraded to Levin spec for racing using imported packages from specialist wreckers, or from Toyota, who bought in a limited number of spares to support the race program. The Levin spec cars had many important differences, rear discs, 4AG engine, larger radiator, larger diff & axles, vented front brakes. The homologated parts list is long, and much of it was from prominent suppliers like AP Racing and TRD. A lot of the originally homologated parts like brakes were further upgraded from 1991 onwards, when freedoms came into the rules. There is a flourishing club in Australia and they remain a cult car in Japan, UK, and USA.
    Current state
    It was purchased with front body damage and with many parts missing (see pics). It is now largely disassembled for restoration. It has its original shell and GpA log book with matching numbers. Many small parts like bolts, clips, bits of trim will be missing requiring visits`to local wrecker.
    Refer to table below for details of current status
    Item Sub-assembly Status
    Body Basic Shell
    (VIN# matches log-book) Mostly sandblasted & undercoated
    Straightened as-required on rack
    Turret and front clip replaced.
    Needs detail work to floors etc.
    Doors Sandblasted & undercoated
    Lots of filler but not rusty.
    Mirrors and fittings OK
    Glass & window mechanisms appear OK
    Bonnet Straight. Needs rust repair to leading edge
    Tailgate Straight. Needs significant rust repair
    Rear ¼'s Sandblasted & undercoated
    Straight but lots of filler.
    Needs typical rust repairs to upper & lower sections
    Bumpers F & R complete with brackets, front un-damaged , rear has been repaired.
    Spoilers F & R new fiberglass copies made off original TRD ones
    Electrical Wiring Complete but needs restoration/replacement
    Lights Complete set undamaged
    Switchgear Complete set but needs restoration
    Engine 4AG Engine Complete fan to flywheel with correct starter, alternator, manifolds etc.Dyno tuned @ 194HP. Has had limited use in 3J category vehicle since complete professional rebuild using lots of brand new parts (crank, rods etc). Note, engine is currently set up with Toyota injection as per pre'92 GpA spec, but can also supply 2 x 45DCOE weber & manifold as per ‘92 bathurst spec.
    Computer Motec. Files available
    Driveline T50 Gearbox with special Close ratio gear set. Fully rebuilt and un-used
    Diff Diff centre with spool completely rebuilt & unused. 4.3 ratio as used Bathurst. Includes provision for oil circulation pump for long distance events.
    Rear axle housing & axles Correct Jap spec “big-bearing" Levin axles. Axles machined for AP rear disc hats.
    Wheels 4 x BBS forged, 15 x 6". Undamaged condition. These are not the ones originally used for racing, but that type are still regularly for sale.
    Clutch Master cyl rebuilt & un-used.
    Puck type race clutch & matching flywheel- tested OK
    Brakes Rear AP slotted vented rotors and AP 2 piston, alloy calipers. Calipers were purchased as “ready to fit" & includes pads
    Front AP rotors as-is. No calipers (AP2361 typically used)
    Pedals Standard
    Handbrake Hydraulic handbrake, master cylinder rebuilt and un-used since. Bracket repaired
    Cylinders Rebuilt and un-used since
    Suspension Rear shocks Bilsteins, checked as OK.
    Coil-over kit, new and un-used
    Rear suspension arms Lower arms rose-jointed. Stripped, cleaned & painted
    Upper arms poly bushed, Stripped, cleaned & painted
    Sway bars Uprated rear sway complete with mountings, needs painting
    Front race one missing but readily available
    Front shocks Bilstein coil-overs, specially made for car. Strut brace specially made for car
    Springs various
    Front subframe Original lightened and seam welded. Needs clean-up.
    Front suspension arms Lower arms missing but patterns available to copy.
    Interior Dash & console Appears complete but needs full restoration
    Instruments VDO oil & temp . .
    New VDO 8000 tacho
    Purpose made dash facia to suit
    Seat Missing
    Steering Column Complete incl wheel, but needs restoration
    Rack Complete but needs restoration
    Fuel system Fillers 1 x drybreak female as fitted to rear ¼ panel. checked as OK.
    Tank missing
    Known major missing parts Radiator, Oil vent tank, fuel tank & 1 dry break fitting, front lower wishbones (rose jointed), front sway bar & links, muffler & pipe
    Mar 2010
    Daniel
    West
    Take the engine, drivetrain, suspension.... then run far away.
    Seth
    He want roughly 20000 based on parts value. Good luck I reckon, unless some one values the car's historical value that much. Which is tossery wank factor thing to value anyway.
    Mar 2007
    nah its a bit sad to see somthing with that kind of history in that way. she's pretty nackerd
    parrot
    I suspect this is Terryo on these forums
    Veteran Klutch's Avatar
    Feb 2010
    Sprinter-Saurus
    Fark that's disappointing to see a Grp A in that sort of decayed condition.
    Instead of being used as a bloody rally hack it should have remained in it's original race spec.
    Oldschool Member
    Feb 2006
    That AE86 was also in Zoom in the late 90's, OMG SIK!
    Could be a good racecar project, I would personally love to see one or two in Gr. A/Gr.C association racing. And the Peter Williamson ma61 Supra if it still exists.
  1. Group N2 Corolla & Sprinter Grand Cup
    By Kid Karola in forum Youtube Chan
    Last Post: 25th June 2012, 04:07 PM
  2. Group A 4age for sale
    By blair in forum Brisbane & QLD Events and Discussion
    Last Post: 15th January 2012, 08:51 PM
  3. My sprinter for sale
    By Blizzerd in forum Perth & WA Events and Discussion
    Last Post: 25th October 2010, 02:40 PM
