Results 1 to 10 of 10
Thread: Clutch question
    My car has an AE92 smallport 4age, JDM bellhousing and ADM T50 gearbox-
    So when I am ordering a clutch kit, should I be looking at ae92, jdm ae86, or adm ae86 clutch kits.
    Also-would anyone be able to tell me what pricing is like for say an exedy heavy duty clutch from where you bought it (i'm in qld).
    Thanks
    Ferny Grove
    they should all be the same as they use the same 200mm flywheel
    20v and ze have difernt size flywheels, but the 16v series are the same.
    Johnny will clarify this or highlight some differences between them all via his naked female technical databse call centre
    BrittanySpears
    Johhny is a walking toyota dictonary. Its cool
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    They will all be the same, importantly same flywheel (as Gilly said). Love it when Toyota parts are all interchangeable
    In ae86fow's and my clutch swap we used the same clutch (Exedy heavy duty), mine an ADM 4AC and his a JDM 4AGE Levin. I have heard of the same kit working on a similar setup as yours, but I meant its all the same anyways
    Can't be sure on retail price for them, ours we got dead cheap Last I saw on here was about the $300 mark, which seems about right.
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
    I disagree. I think a smallport will have had a 212mm flywheel on it from factory (just checked the Xtreme catalogue, and it gives a late AE92 as 215mm clutch).
    But it all depends what flywheel you are running now. It would probably be best to drop the box and measure it up before ordering.
    200mm diameter clutch face = 4AGE from AE86, AE82, early AE92 or other 200mm clutch.
    215mm dia. = late AE92 4AGE or any 20V
    Rob
    Moorabbin
    Does this mean that the 215mm clutch as listed in the Xtreme catalogue is intended to be fitted to a 212mm flywheel? (with 1.5mm overhang)
    Joel
    Blackwood
    For some reason I thought that flywheel/clutch sizes were designed in inches.
    Thus Bigport 4AGE = 8" = 203.2mm
    20V and later model 4AGE = 8.5" = 215.9
    Sounds about right.
    AE86 4AGE "Slowly but surely"
    Yeah, I think it's 8" gets called 200mm, 8.5" is 212/215 and 9" is 225 for the ZE.
    The whole 212 vs 215mm thing I think depends on who you ask. I'd hazard a guess that the measurements can be used interchangeably. I certainly do.
    So Xtreme 215 clutch will fit a 212 flywheel.
    Rob
    Moorabbin
    Cheers for that, makes sense
    Thanks heaps guys
  1. 212mm clutch question
    By trikzlane in forum Technical - Questions
    Last Post: 1st August 2011, 02:20 AM
  2. another clutch question
    By pieman18 in forum Technical - Questions
    Last Post: 21st August 2010, 06:41 PM
  3. Quick clutch question and spigot question
    By wideslider in forum Technical - Questions
    Last Post: 9th August 2008, 12:45 AM
  4. clutch question
    By muldog86 in forum Technical - Questions
    Last Post: 3rd January 2008, 10:03 PM
  5. clutch question
    By meadan in forum Technical - Questions
    Last Post: 28th March 2007, 10:47 PM
