I've decided to sell my complete RWD 4AGE bigport 3 Rib Bolt in package for an KE70 / AE71 / AE86
The only thing missing is the RWD exhaust!
Engine Setup
- ADM 4AGE bigport with 190000 km in VGC (reason for removal was GZE installation) - new timing belt
- ADM Ae82 Oil cooler and some line
- JDM Bigport RWD Inlet manifold with new ACL gaskets
- AE82 External thermostat housing for conversion
- ADM AE82 bigport Loom, coil and ignitor, Map sensor - will be converted to RWD on deposit
- Your choice of an ADM or a JDM ECU (ADM for economy, JDM for some extra top end power)
- 200mm Flywheel with new Standard duty Exedy clutch
- Intank High pressure pump to get it going, use as a lift pump with external, not sure how much it'll surge.
$1000
04 22666828
