Results 1 to 10 of 11
Thread: koni's ?
    Senior Member JDM-086's Avatar
    Dario
    Melb
    hey im trying to get some red koni adjustables all round but i wanna see which i can buy that are made for other cars thatll fit the 86. as you can imagine as soon as i told them it was for a hachi there price was considerably more than other cars. so i was wondering if anyone can tell me some rough measurements so i can try match them myself or if there is a known fittin eg. monaro koni adjustables fit an ae86.
    this is for front and rear btw
    Julz01
    Celica or mr2 inserts for the front with a spacer, In the rear monaro/commonwhore shocks. Cheap alternative are whiteline shocks which apparently are re badged koni yellows.
    All has been covered in the suspension thread
    Felix
    Gold Coast
    I will hopefully be selling some koni reds (non adjustable) for the rear soon
    Jonathan
    The Koni Reds I have ARE adjustable and have a fair range, as all the reds are I think. You just have to unbolt the bottom, compress the shock all the way, and turn it till you feel the keyway engage, then you have about 3 turns of adjustment. On full stiff was way too stiff even with the leaf spring on me KE55. I put them on full soft, and adjusted them up a little as they wore in. Part number was same as older commodore wagon I think.
    Dario
    Melb
    ok so you can get commodore wagon koni reds all round and theyll fit the 86? which commo wagon specific?
    Jonathan
    I don't know what is available in each brand. Koni Red are available for most cars, and are adjustable if you unbolt them. Koni yellow are only made for some cars, the obvious choice sports cars, but are externaly adjustable.
    If you want original length rear shocks, then order them for AE86 or AE71, TE72, AE95, TA22, RA23, AL25. They should all be the same shock, or near enough.
    But most want a shorter shock. I like the dimentions of rear shocks for these cars: XT130, ST141, KE36, RA40, RA60, AE70 van. This is all the one shock, and will fit perfectly and be short also. About 80mm shorter extended length.
    Or rear shocks to suit these cars: KE30, RT40, Commodore wagon (VB,VH,VL,VN) are also good but not as short.
    For short stroke front inserts (used with spacer and some sorting out etc), try ordering for one of these cars... all slightly different lengths but right diameters and stuff.
    ST162 Celica
    ST185 Celica
    AE92, USA spec
    SW20 rear
    ^^ they are the common ones people use. Also:
    SV11, SV21?, Holden Camira, MA61, Cressida etc front strut inserts would also work. Its up to you to do some cross referencing yourself.
    Paul
    West
    SW20 rear ???
    so sw20 rear shocks in a front ae86 strut ?
    Felix
    Gold Coast
    hmm interesting... I'll have to suss this out on the weekend, i'll get back to you after that
    Dario
    Melb
    hmm rang around. sw20 rears are more expension than ae86 specified fronts. the commodore rears are around the same price. and couldnt find xt130 or st141 at all
    Dusty
    Lynbrook
    you pay for quality stop being a tight ass and pay up
  1. koni reds
    By Rich_86 in forum Car Parts For Sale
    Last Post: 29th February 2008, 05:28 PM
  2. koni yellows
    By merc-blue in forum Car Parts For Sale
    Last Post: 29th September 2007, 03:05 PM
  3. koni adjustables
    By dustyae86 in forum Technical - Questions
    Last Post: 21st November 2006, 10:42 PM
  4. Yellow koni won't adjust
    By v-tec in forum Technical - Questions
    Last Post: 1st May 2006, 01:39 PM
