Results 1 to 3 of 3
Thread: 4agze coil pack
    Jamie
    hows the best way to tell if the coil pack is buggered. the motor is missing and u can hear sparks jumbing ? all the plugs and leads are fine
    if it is buggered what are they worth and where can i get one
    cheers jamie
    Veteran slide86's Avatar
    Huw
    Hills
    look around on different forums, they pop up everynow and then
    you should be able to see where the spark is jumping, have a look at night, there will be a nice blue light that will show the fault
    Jonathan
    Use a Ohm meter (multi-meter) and measure the resistance of the 2 windings.
  1. How to Wire coil on plugs? 20v ST w/ Aftermarket ECU w/ 4 coil pack
    By Fine Taste in forum Technical - Questions
    Last Post: 5th August 2014, 07:50 PM
  2. 2nz coil pack
    By evil86 in forum Car Parts For Sale
    Last Post: 8th January 2012, 10:10 PM
  3. coil pack troubles
    By R&D Mechanical in forum Technical - Questions
    Last Post: 15th October 2009, 09:44 PM
