Results 1 to 5 of 5
Thread: need seals help
    Jun 2007
    hey guys only new to the ae86 just got my first one and cant be more impressed i do need to do a few things to iut though and ive searched this forum and cant find any thing i need a rear main for a 4agze i need a center bearing and a seal in the front of the diff near the yoke. dose any one know part numbers and roughly how much. my drive line consists of a t50 box and a t series rear end. thanks for any help guys and gals regards shaun
    Jonathan
    There is a Genuine Parts thread in Tech Articles that has some numbers, has the rear seal number at least. It will be updated again sometime.
    Most service and replacement parts like seals and bearings will be alot cheaper at Burson or Repco rather than Toyota. But if you go to Burson, you just have to say you want a diff seal for a old Celica and stuff like that. All 4A rear main seals should be the same, or similar enough. The tailshaft centre bearing from Toyota will cost heaps, maybe $300?
    offtopic, but welcome to 86dc,
    you should put some info and pics of ur ride up in members cars. seeya on the forums
    All those parts you mentioned you could get from CBC.
    You could find you nearest location there.
    Just ask for
    center bearing AE86.
    rear main seal 4age
    pinion seal for t-18 diff, or ae86 import.
    Or you could take you seals out and take em with you. All brand of seals all have the same serial number. So doesnt matter if you get it from toyota, bursons, repco, all seals have a unique number and its the same no matter who you get it from.
    Insert witty comment here....
    Jamie
    i just replaced tho's seals in mine 4agze i just ask for seals of a ae92 twin cam
    i got cams seal, rear main, front crank shaft seal
    cheers
  1. Valve Seals
    By DR86TY in forum Technical - Questions
    Last Post: 8th April 2009, 01:37 AM
  2. rubber seals
    By freddie in forum General Topics (No Technical Questions)
    Last Post: 27th June 2008, 12:04 AM
  3. Where to get new rubber seals?
    By Jarrod in forum Technical - Questions
    Last Post: 26th September 2007, 11:28 PM
  4. Injector seals
    By Pat_AE86 in forum Technical - Questions
    Last Post: 4th May 2007, 06:43 PM
  5. seals for sprinter
    By muncher in forum General Topics (No Technical Questions)
    Last Post: 11th August 2006, 09:55 PM
