well my exhaust fits nice and close, heres a test fit:
UPDATE: I finally managed to do a little bit of work for the first time in about 2 weeks. I have been really sick and have been too sore and lethargic to do anything. I think I am getting better now though.
Also I will soon have another temporary camera on the way.
UPDATE: IT runs!!
I have found a few interesting things though.
- Noise: the noise level is suprisingly manageable, yeah I still plan on making a variable exhaust but I think I can safely avoid it for a while. The Lukey muffler does make an interesting sound though that I can't say I tottaly like, but I might be able to get used to it.
- I have problems with the engine idle. Normally it's fine but sometimes it just dies. After I have driven it it's sometimes more likely to do it.
- Twice it has tottaly cut out on me and I had to turn the key off and on again to get it running again.
- The engine is rough when I get on and off the throttle, I doubt this is due to the engine mount but I will double check.
- The TRD engine mount I am running suprisingly doesn't send much vibrations to the cabin. I will keep it in there and try putting the other one in and see how it feels. It sure holds the engine in place well too.
- My "commercial" brake master works a treat, it's perfect and I see no reason that I will ever have an issue with it.
I have issues which has me bothered but there are some upsides, I have an ignition problem which I am familiar with which limits my power and revs but even still it still has a decent amount of power for the current setup, so I must of done something right.
Also when the engine does idle it does it well, I can place a washer on intake box when the car is running and it pretty much doesn't move.
UPDATE:
- My engine is no longer rough getting on and off the throttle, a quick adjustment of the TPS fixed that (thank to Kev- RIP buddy)
- The TRD engine mount does transmit vibrations into the cab afterall, on deacelleration it's a bit nasty and I will try a normal mount and see how well it works.
- My idle problem is still there, sometimes it's fine and then it just dies. I will look into it soon.
- My car has used an obscene amount of fuel in the 150km I have driven it. I have gone through something like $25 worth of fuel. I just hope it's because I have been giving it hell in that time.
- My fuel pump relay has been clicking on an off rapidly. When I took it apart I found that it was the most unusual relay I have ever seen. It has 2 coils activating one set of contacts. One of the coils was discoloured and had a significantly higher resistance so I thik it's stuffed. I am not sure where to get another one of these, I rang up a toyota dealer and the number didn't mean much to him. I might just run an OR gate though 2 conventional relays and then add some capacitors if it's still clicking a bit.
I plan to shortly:
- Trace back what the spare wire is in my loom
- Change the rear brake pads to some super soft low temp items
- Try the following ignitors: 16V, 20V and Camira and see if it fixes my ignition problem
- Wrap up my body loom a bit more to make it look completely factory
- Replace and rewire the factory fuel pump relay.
I also may have the use of a camera again shortly so I will post some pics up.
