I found some more useful links:
a seam weld job in Volvo:
I am looking into to doing some serious bracing on this thing so I have started looking for info.
Another F20c into 86 conversion page:
I managed to do some more work on my strut brace, I intitually started with some plain pates as shown in this pic bolted to the top of the strut tower on the left:
these two rings were made of 3mm thick stainless plates and were quite heavy. While the holes where in the right spot I had to do some heavy die grinding to bring them to fit on in relation to the middle hole.
After this I started to drill holes to lighten them and I also welded on two cro-mo tubes in short vertical section, these will be taking the lateral stress. These are 22 x 1.5mm. I also removed the un-needed material, filed the welds and lastly shot-peened it so it would paint better later on. Interestingly even though the stainless is much harder than normal steel it had a dimpled effect from the shots while the Cro-Mo tube had next to nothing, no wonder it's such a bitch to drill through. Heres how they ended up looking:
In a little bit of free time I managed to shape one of my Cro-Mo bars for the main sections. This is thinner while still having a 22mm diameter it only has a 0.9mm wall thickness, it doesn't sound like much but it is Cro-Mo and I have a unique idea in mind.
this first piece has purposefully been kept as straight as possible for rigidity and goes directly to the tube above one stud. It will be braced more at each end and this I hope will trasfer the stress directly into each stud. I am not going to reveal the design I am using for the main section yet, but instead just keep posting pics as I work on it. I will say though there is a second reinforced pipe going across as part of the design.
I managed to have a small set-back the other day. After doing something I won't name I heard a real loud ticking noise from the engine, for a moment I was thinking "hmm, I must of broken something inside the engine, oh well" but then I recognised that it was the sound of an exhaust leak. Looking under the bonnet I saw that one of my primary pipes had completely broken off the flange and there also was a crack under number two. A friend saw this and said it was because I didn't have a brace from my trasmission to the bottom of the extractors, I don't know if this is right but it sounds right so I will make such a bracket in a the near future. Heres where it cracked:
I took the pipe off and welded it back up mostly using a Tig but I used a Mig for where the Tig wouldn't reach and I have since put it back on the car without any more issues in that area.
