Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Help needed ASAP with firing order
  1. #11
    Veteran slide86's Avatar
    Huw
    Hills
    when it cranks, is it a fast crank, or slow.
    or does it crank ok and then stop like the engine is jamming then start again. these are the sort of things that indicate if the timing is advanced way to must or retarded.....
  2. #12
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    check what number 1 is on the cap, u may have it pointing to the wrong one, it should say it on the cap my 16v did, JDM bigport??
    MY JZX83 (clicky)
  3. #13
    Oldschool Member
    Jul 2006
    Have you tried taking off a rocker cover and making sure you're in the compression stroke on cylinder 1? You may be out of phase. Seems really weird if it won't go and everything else is right.
  4. #14
    Setting timing simplified.
    [attachment=16911:ig_11.jpg]
    If you've done that correctly and it's not running start looking at other things.
  5. #15
    May 2007
    Thanks again guys......
    Ive just gotten home from work. I loaned a mates XF Falcon ute. My god I forgot what i was like to drive a boat on the road.. LOL
    Im about to give it another go. Thanks for posting up diagram Ken.. You're tops !!!! Thanks to everyone else for such quick replies too... I'll keep you all posted..
    May 2007
    Sorry....
    When I crank it over, it cranks just like its ready to start as usual, and it keeps cranking until I turn it off or run out of battery.
    May 2007
    IT LIVES IT LIVES.............!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I'd like to thank Jesus, my mum and dad........................My wife......we did it baby!!!!!!!!!!....LOL
    Thanks guys. You guys are ace....!
    Huw
    Hills
    what was it??
  9. #19
    May 2007
    I'm not entirely sure what the problem was....
    I'm 90% convinced that I wasn't lining the 2 indents on the dizzy. So the dizzy was probably a tooth out. Essentially operator error... But I know now what I did wrong so I want do it again....
    Cheers to everyone for the help
  1. Wtb late ae82 BIGPORT INJECTOR PINK TYPE, in workin order asap
    By 4ag te72 in forum Cars or Parts Wanted
    Last Post: 12th March 2011, 01:10 PM
  2. QUICK QUESTION: Right firing order
    By keimeier in forum Technical - Questions
    Last Post: 12th September 2010, 09:03 PM
  3. firing order for a 4ag
    By TRD_86 in forum General Topics (No Technical Questions)
    Last Post: 20th February 2008, 08:19 PM
  4. Parts needed asap.
    By Dish in forum Cars or Parts Wanted
    Last Post: 2nd April 2007, 06:15 PM
