Results 1 to 2 of 2
Thread: Clutch and flywheel
    Member tristybomb's Avatar
    Tristan
    Hay pple does anyone know the tourqe settings for a pbr std 4age clutch and what are the settings for the flywheel too???
    Im also gonna lighten it a bit too does anyone have a pic of a std ge flywheel thats neen lightened so i know where to take the weight from.....
    Cheers!!!!
    Veteran biggo's Avatar
    Nick
    Noosa
    seeing as no one replied to you question I will
    the manual states 14ft-lb for clutch pressure plate torque. I just as I see fit cos 14ft-lb isnt much
    Lightening a flywhell is easy, on the back is all the taht blank between the center and clutch surface spine, any clutch place can lighten it a bit, mine just got ballanced in stead. Also it's got to get it refaced at the same time
  1. 212mm flywheel and clutch
    By Nic19 in forum Car Parts For Sale
    Last Post: 12th December 2009, 09:59 AM
  2. what clutch and flywheel do i use
    By richieke70 in forum Technical - Questions
    Last Post: 1st May 2008, 12:06 AM
  3. clutch and flywheel
    By egg_83 in forum Cars or Parts Wanted
    Last Post: 26th March 2007, 06:20 PM
  4. clutch and flywheel.
    By redsprinter in forum Technical - Questions
    Last Post: 5th November 2006, 04:19 AM
  5. clutch & flywheel
    By Sly in forum Technical - Questions
    Last Post: 12th September 2006, 11:51 PM
