Results 1 to 10 of 10
Thread: Front brake lines?
    Oldschool Member
    Mar 2007
    Are the front brake lines on a KE70 able to go straight into the calipers off a sprinter when changing struts over,
    or do i need to get the ae86 brake lines as well?
    Many thanks
    Ferny Grove
    need AE86 brake lines
    the fitting will thread in but they have a different mounting face
    they do work with each other but its nor reccomended
    Nat
    Newcastle
    Good time to upgrade to braided lines, that's what i did when I swapped to ae86 front end in mine
    Feb 2007
    my lines fitted in easily. they were tight, but its been fine for months.
    (My ke70 has ae86 struts and ae86 calipers)
    Dave
    yeah i cant see why they wouldnt fit
    what do you mean by
    "the fitting will thread in but they have a different mounting face" gilly?
    - Blaise Pascal
    Ferny Grove
    the AE86 caliper has a convex (domed) female port on the caliper therefore the AE86 hose has a concave (dished) male fitting
    the Ke has the opposite so by using KE hoses in AE86 calipers you have 2 convex fittings meeting each other. it works they still seal but not as desirable as the correct concave meeting convex method.
    in saying that i didn't use AE86 hoses i'll do stuff like that in my car but will rarely reccomend to the public if it is not the correct way of doing it
    Oldschool Member
    Mar 2007
    Nice question ke70dave, was wondering what that meant myself thanks for asking before i did.
    Also good answer Gilly am glad there are people with your knowledge.
    So does anyone know where and how much i can get a set of braided lines for?
    Also as a temp measure some thread tape that plumbers use would be an effective measure to seal the thread would it not?
    Dave
    umm you may find that that plumbers tape will be eaten away by the brake fluid. you should have no trouble in doin the threads up tight enough so that they seal properly. im not exactly sure what gilly is talking about, but everytime ive done up a brake hose it has become "tight" well before the face of the whatever gets close to the caliper. like there has been heaps of thread showing outside the caliper. also as gilly stated (Daym gilly you get alot of mention) he has used ke70 lines with ae86 calipers with no trouble
    if you have both parts, try screwing them together, and see if its a firm fit.
    just a tip, try and get yourself a pipe spanner as i HATE undoing/doing up brake lines with just ordinary spanner...ive stripped so many....
    - Blaise Pascal
    Ferny Grove
    word up to the pipe spanner!!!
    i'll get pics showing what i mean
    Rob
    Moorabbin
    super wrench FTW
  1. 86 braided brake lines- front
    By 70rolla in forum Cars or Parts Wanted
    Last Post: 5th December 2011, 11:41 PM
  2. wtb-ae86 front brake lines
    By john84ie in forum Cars or Parts Wanted
    Last Post: 23rd July 2010, 10:00 AM
  3. KE70 front brake lines
    By Simon-KE70 in forum Cars or Parts Wanted
    Last Post: 11th January 2009, 12:11 PM
  4. wtd: adm front brake lines
    By riceburner in forum Cars or Parts Wanted
    Last Post: 2nd September 2008, 03:17 PM
  5. braided front brake lines
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 23rd July 2008, 05:21 PM
