Results 1 to 6 of 6
Thread: Valve Stem Oil Seals
    Nat
    Newcastle
    Hi guys,
    Well due to circumstances outside my control I have to postpone my 4age install. This means i need to look at replacing the valve stem seals in my 4ac so that i can stop gassing people at the lights, lol
    I know they aren't real dear but I've never replaced a set before, so my question is, how hard is it? Do I need to remove the head to do it? Just trying to get my head around it, if its too big a job I will just keep topping up the oil, ha ha ha
    Thanks in advance guys
    im not exactly sure how its done.
    im thinking your gonna need a valve spring compressor, and from what ive heard its a pretty fidly job. best to take the head off the car and do it on a work bench while sitting down
    you may find it easier just putting up a WTB and get a complete new 4ac. you will be able to get one cheap as, someone is bound to have one or three lying around.
    - Blaise Pascal
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Just keep toppin up the oil, its only a 4ac.
    To do you will need to remove the head from the motor, remove cam, and use a valve spring compressor and then renuild it properly.
    Jonathan
    This is not a easy job, and it is fairly hard also. Most times you do this, you also have the head off the motor, and you are also replacing the head gasket and getting the head planned etc. Generaly, you have to take the valves out, then you may want to regrind or lap the valve seats.
    There is a way to replace the valve stem seals without taking the head off or taking the valves out. You take the cam cover off, take all spark plugs out. On a cylinder that has both valves closed, hook up compressed air to the spark plug hole, which keeps the valves up. Then compress the valve springs (with a custom tool you just made) and pop the retainers off, and take the springs off. But I don't think I have ever done this method myself.
    But your oil smoke can also be from the rings. Maybe it would be as easy to get a replacement 4A-C off someone.
    Veteran slide86's Avatar
    Huw
    Hills
    i have done the method that johnny speaks of.
    you have to be VERY careful that you dont loose the valve into the cylinder, that makes baby jesus cry.
    either using the compressed air OR rotate the engine till the piston is on TDC will work.
    dont loose any of the collets or retainers, they are small and are easily lost, specially in the head and down the oil return, again, baby jesus will be crying at that.
    doing the job with the head of is a bit easier but takes more time (with the head removal and all). doing it in car is quicker but not recommended if your not confident from the start.
    Nat
    Newcastle
    Hmmm, bollocks to that
    25w/70 ftw!!!!!!
    Thanks anyway guys, much appreciated
  1. 20V Valve Stem Seals
    By 70XIN in forum General Topics (No Technical Questions)
    Last Post: 27th October 2010, 02:05 PM
  2. Valve stem seals worn ?
    By GEMTA22 in forum Technical - Questions
    Last Post: 12th September 2009, 12:11 AM
  3. Valve stem seals - 4AGE
    By adam in forum Cars or Parts Wanted
    Last Post: 3rd July 2009, 11:54 AM
  4. installing valve stem seals
    By Sam_Q in forum Technical - Questions
    Last Post: 6th July 2008, 11:06 PM
  5. 20v valve stem seals
    By bogdan in forum Technical - Questions
    Last Post: 13th October 2005, 09:40 AM
