Results 1 to 9 of 9
Thread: heater problem
    stefan
    vic
    eastern suburbs
    as the title states.
    my heater will not blow hot air what so ever, the hoses from the engine are aftermarket (light blue) and they have pressure so water is circulating thru the heater. the switch in the dash is not broken because i pulled out the glove box to check that. is the core stuffed??? any help would be appreciated
    cheers,
    stefan
    Ferny Grove
    is the cable still connected to the heater tap? its in the engine bay
    (i'd try to find a pic but i don't have a 16v handy anymore )
    Veteran slide86's Avatar
    Huw
    Hills
    are you sure that there is water going through the core?
    is the hearter tap jammed closed? this will prevent water from flowing through the core, but the pipes will still have pressure in them.
    id be checking the heater tap operation first
    stefan
    vic
    eastern suburbs
    then whats the cold to hot slider connected to? when i pulled out the glove box it was attached to a mechanism inside the cabin behind the dash
    Huw
    Hills
    the cold to hot mechanism is attatched to that and also to the heater tap on the firewall next to the clutch master.
    the cable comes off these sometimes, that will cause the 'no hot air'
    get someone to sit in the car and move the slider whilst you monitor the heater tap, you will be able to see if the cable is actuating the tap or not
    Jonathan
    The hot/cold slider is attatched to a blue cable. The blue cable goes to the engine bay and opens and shuts the water tap on the firewall.
    There are other cables that also control the vent doors on the heater box, which also need to work.
    stefan
    vic
    eastern suburbs
    ok in the last 10 minutes i have established that i have no heater tap, damn ex race cars . i beleive it is some models of celicas that share the same heater tap. does anyone know which models they are?
    Huw
    Hills
    well, if you have no heater tap and the lines are hooked up correctly, theoretically you should have a heater all the time that you cant turn off.....
    Veteran driftism's Avatar
    Andrew
    Watsoia
    i had no heater tap on my old car and i had hot and cold when i wanted it... dunno why you need the heater tap in the first place.
  1. Where to buy AE86 RWD heater hoses and thermo & heater gaskets
    By oz_eight6 in forum Technical - Questions
    Last Post: 22nd October 2012, 11:42 PM
  2. Replies: 6
    Last Post: 30th May 2011, 11:12 PM
  3. KE70 Heater
    By ke70 xx in forum Adelaide & SA Events and Discussion
    Last Post: 5th July 2010, 11:32 PM
  4. WTB:[VIC] - AE71 heater core & Heater tap..
    By tc-rolla in forum Cars or Parts Wanted
    Last Post: 16th August 2009, 02:08 AM
  5. ae86 heater core (heater box )
    By 131-sam in forum Cars or Parts Wanted
    Last Post: 28th March 2008, 04:24 PM
