Results 1 to 6 of 6
Thread: wierd noise
    callum
    qld
    tully
    hey everyone. iv got a 4agze, and its been running a bit rough the last two days so i was checking it out and found it had very little oil, so i filled it up, and that solved that.now its started making a really wierd noise. when im on about 13-14psi of boost at 4500rpm to 5500rpm (didnt want to go any higher) there is this wierd kind of sucking/scraping metal on metal noise. its never made this noise before even on redline. what the hell could it be. the oil from the engine is the same that goes through the supercharger...so could i have farked the supercharger by having low oil?
    your friendly neabourhood electrition. for cash jobs pm me!
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    those superchargers dont run that amount of boost for long as it melts the internals, my guess is that your blower is farked
    MY JZX83 (clicky)
    Veteran biggo's Avatar
    Nick
    Noosa
    check the harmonic balance key, they are known to fail and still work kinda
    Senior Member riceburner's Avatar
    Dont the super chargers have there own oil.
    Im 90% certain they dont use engine oil. Yes 13.14psi will soon kill the charger.
    If your running kinda rough id be looking into vacumm/pressure holes first.
    Insert witty comment here....
    Dusty
    Lynbrook
    these chargers have thier own oil, if the revs are sitting up higher then i would say vac leaks... but that amount of boost supposedly kills them take you intercooler hoses off and spin it by hand and see if it puffs, if it does it sounds like its probably a fucked charger.... but if its still getting boost then maybe not
    callum
    qld
    tully
    nah revs are normal. hmm. looks like its turbo time. im glad that its tax time
  1. Wierd timing issue...
    By jaydos in forum Technical - Questions
    Last Post: 12th October 2011, 09:34 AM
  2. wierd noise
    By Ke70alex in forum Technical - Questions
    Last Post: 10th February 2010, 10:26 AM
  3. brakes feel wierd.
    By Ade_Mc in forum Technical - Questions
    Last Post: 3rd February 2009, 01:37 AM
  4. wierd toyota photos
    By haado gei in forum Toyotas in the Media
    Last Post: 30th July 2007, 04:21 PM
