Results 1 to 10 of 12
Thread: How to get a speed signal??20v silvertop
    Oldschool Member
    Sep 2006
    so iv put a 20 silvertop 4age into my ae85 which had 3au previously
    and the car obviously isnt running 100% more like 80% and i think this is to do with having no speed signal to the ecu.
    my dash and speedo work completly fine.
    would connecting a wire from here (speed signal)
    to the L11 Spd pinout on the ecu create the speed signal and make the engine peform better?
    thanks
    Elite rthy's Avatar
    Leo
    Tulla
    i believe there should be somekind of speed sensor on the gbox?
    Jonathan
    ^^^ the speed "sensor" in the gearbox is the speedo mechanical drive. And that goes to the speedo cluster.
    I havn't experimented with the 20v ecu. Its worth a try. Only 1 wire, not too hard.
    Oldschool Member
    Sep 2006
    hmmm yeah im sure the ecu doesnt read any speed signals through the gearbox???it just goes to the dash for the speedo
    oh and also my rev limit is at about 7,800 atm
    Senior Member riceburner's Avatar
    Although i cant confirm for the 20v, but the 16v ecu doesnt really need the speed sensor. Its only really used for fine triming of fuel mixtures at idle and other certain areas, like closed lopp etc etc.
    But no speed sensor signal is from the gearbox. Only signal that comes from the T50 is for the reverse lights.
    There is a magnetic read switch in the rear of the instrument cluster, just underneath in behind where the cable goes in and you simply earth the screw as in the picture, then pin N# 7 (or use the screw as in the pic) on the plug for the actual signal.
    Straight to the ecu speed input plug, reset your ecu's error codes (take of negative battery terminal for 5mins) and away you go.
    If anything it will give a slightly smoother power delivery maybe slightly better fuel economy.
    I dont think it will help with max rpm. Maybe fuel cut point but not rpm.
    Insert witty comment here....
    Will
    was about to suggest you find my post on this, but it loosk like you foudn it already (i took that pic)
    i tried this on my 16 valve, but it didnt seem to do anything, still rev cuts at 7200 as far as i can tell.
    Elite rthy's Avatar
    Leo
    Tulla
    iv got these thing on my tailshaft and this sensor thing, i donno what it is
    edit: lol nevermind,
    i have one of those aftermarket reed switchs and what seem to be magnets on the tailshaft...
    Oldschool Member
    Sep 2006
    thanks FKN16v real helpful i guess ill try it and hope for the best, and yeah i had a look at your post still didnt really understand completly though
    Oldschool Member
    Sep 2006
    ok so iv done exactly this..and the results well power delivery's smoother, seems like more tourqe down low, rev cuts still at 7200 :angry: (it wasnt 7,800 before as i said it was got my numbers mixed)
    alot better than it previously was i think but still not that happy with 7200 >_<
    That could be a warn out tacho, old coil, or your tacho wire of the coil is old, dirty, etc etc.
    Would your tacho even spin to 7800rpm. I cant see the use of such a high rpm without motor mods. You got no power to gain after 6500-6800rpm anyways.
  1. [PERTH] 20v Silvertop with ECU and loom, other 20v things for sale.
    By quadeyquade in forum Car Parts For Sale
    Last Post: 12th August 2012, 10:00 PM
  2. 20v silvertop
    By lstylr in forum Car Parts For Sale
    Last Post: 8th July 2008, 11:57 PM
  3. 20V silvertop
    By sr20det in forum Technical - Questions
    Last Post: 23rd May 2008, 01:57 AM
  4. silvertop 20v
    By spoon in forum Car Parts For Sale
    Last Post: 19th April 2008, 05:07 PM
  5. silvertop 20v or blacktop 20v
    By Cj_sullivan in forum General Topics (No Technical Questions)
    Last Post: 6th September 2006, 12:42 PM
