apparently there not that hard to get, i found a few of them at the wreckers. not to expensive either.
cheering :greenbounce:
HOW LIKELY IS A SMALLPORT BOTTM END WITH 190PSI IN ALL FOR GOING TO HOLD UP WITH A TURBO. TD05 EXTERNAL WASTEGATE ON APPROX 7PSI.
1982 KE70 - Red - Meshies - Madhouse Lip - Lowered - Custom plates (KE70) - and much more to come !!!!
forgot to mention they were obviously only fwd ones, are they much trouble converting to rwd?
cheers, issa.
It will hold up perfectly fine on a aftermarket ecu and a good tune. The tune is the key. I was running td04 turbo on 12psi on a stock*** 3ribbed bottom end. With metal headgasket. Running a stock smallport head. Drove it to a 13.0
Early axles...
i was just joking mate Toyota never made a 20V 4AGZE, 20V were only 4age, 4AGZE were only 16V!!
Id say the a smallport with 190psi is an high comp gze 8.9:1 dont pump too much boost!!!! Or is it just an na engine??
are you sure? i mean im not positive but according to they made a silver top 20v only, or is this wrong or did i just read incorrectly.
cheers, issa.
btw what model 4agze is supposed to be the most powerful, or cope with the most power unopened?
Lol, i think you'll find that a 20v is a 4aGE, GZE means supergharged
I think you may have read it wrong as mentioned above the 4agze only came out with 16v head.
The ae101 model ze is the 'most powerful' in stock form at ~125kw
which is a smallport.
