Late, 7 rib block bigport. 200cc low resistance.
If you need the part number I will have a look.
Different spray head to grey's.
the wire plug has round sides like my gze injetors? is the number on the sides relevant? part no?
If you tell us the part number on the injectors, I can tell you what motor its from. If that helps.
ok the part number is 23250-16070. what are the gze injectors if these are 200cc
Went out in the shed. Part number 23250-16070 is for the late, 7 rib block bigport engine, which I have here in my hand.
They are 200cc low resistance injectors. Mine came out of a FWD engine I bought at EKW years ago.
Jonny will confirm but I believe they were in the early AE92's?
4AGZE is a red/orange 365cc injector and yes they both have the same"E" connector.
Someone will have the part number for these.
Parrot is right. My computer says 23209-16070 are 4A-GE injectors from AE92 or AW11 '87-'89.
4A-GZE injectors are about 365cc. And some will say 23209-16060 or -16061.
