MY REVERSE LIGHTS(both) ARE NOT WORKING, JUST CHANGED THE BULB BUT STILL NOT WORKING. ANY IDEAS????HELP
CHEERS
connections to gearbox, passenger side, they may be unhooked
does anyones reverse lights work?
not many 86's do
JAPANESE DOMESTIC MARKET AS F*CK!!! hmmm, when you prenounce it properly, it sounds gayhow bout that.
Yep, passenger side of gearbox there are two wires connected to a switch. Check they are connected.
With your ignition on, you should get lights in reverse. If not then pull the two wires off and connect them together. This should give you lights. If not you have a problem in the light circuit. Investigate further. If you do get lights then you have a problem with the switch in the box.
yea i think theres also a fuse box under the driverside.. check there as well i think theres a fuse for the reverse or tail lights
My reverse lights work! Am I special? :greenbounce:
no ur not just have working reverse lights
could be a fuse, could be a loose connection, also could be the switch on your gearbox have you checked that aswell???
in my experience, it's mostly a bad terminal on the box, from road grime etc.
get a can of electrical contact cleaner, disconnect the wire from the terminal, spray it all over, wait 10mins and try it again.
