Results 1 to 5 of 5
Thread: Headlights not working..
    Mar 2006
    Hi all,
    i have problems.....................
    When turning on my headlights, position 1 (parkers) everything works fine.
    Position 2 (headlights) don't come on! but the high beam light on the dash does come on. High beams are not on.
    Using the stalk, high beams come on in both 'on' positions, (pushed forward) and the flash (pull backwards).
    Summing up, headlight do not work when the switch is on, but high beam light in the dash comes on.
    Anyone elese had this problem? Could it be the headlight switch?
    Need to solve ASAP! Cant drive in the dark!!
    Cheers,
    Phil
    I once had my headlights work intermittently due to the switch being iffy. But you are best off tracing things out with a multimeter to find what is really wrong before changing parts.
    Mar 2006
    soz, forgot to mention no power going to the headlights as well.
    May have to pull out the switch to check it......bugger.
    WAIT!!!
    headlights just came on for a second when tapping (whacking) the side of the switch....
    gotta go to work now, will keep playing with it tonight.
    Rob
    Moorabbin
    Yeah the switches are notorious for failing, you have to do something with the pcb on the back of the switch iirc (search around it has been covered on a couple of different sites/forums). I think the soldered contacts come loose and you have to re-solder them.
    My last sprinter used to do it (sometimes at the most inopportune moments like going around a corner or down the freeway) but I never got around to fixing it.
    Mar 2006
    PROBLEM SOLVED!!!!!!!
    turned out that the solder joint behind the steer wheel had fallen off,
    AND
    The wire (at the other end) had fallen out of the plug under the wheel!
    Note for all;
    When i pulled off the indicator mount on the steering shaft it turned out that i had
    about 6 dodgy solder joints (high beams, indicators)
    Recommend anyone that has had troubles remove this, turn it over and have a good look.
    Phil
  1. tacho not working
    By Shitbox in forum Technical - Questions
    Last Post: 5th December 2011, 12:07 AM
  2. wipers not working
    By pfrats in forum Technical - Questions
    Last Post: 2nd October 2011, 02:22 PM
  3. Best way to get speedo working right?
    By haydenz in forum Technical - Questions
    Last Post: 14th September 2009, 09:45 AM
