Results 1 to 10 of 12
Thread: Popping Exhaust
    Hi guys, I recently unbolted my exhaust and after reattaching it, my car is popping like mad when I take my foot off the accelerator. Could this be caused by not sealing the previously dettached areas properly? I heard some older carby engined cars do the same when sealing is not good enough along the exhaust system. I was also told that the type of gasket I used (i.e the silver stuff with the little holes in it) doesn't need sealing with gasket goo? any help would be greatly appreciated as I am attracting too much unwanted attention and it's getting really ennoying.
    EDIT: Is this only caused by air getting into the exhaust system and igniting? if so, are there any other things I that can also cause this problem
    riojin
    you find that anoying! i love that noise. my 4ae does it and so did my 250 xflow outta my last car. my mates xr8 boss did it after he got extractors put on it.
    i dont what causes it but i thought it was a normal thing. i like it
    I dont mind the 'normal' kind of popping but my problem is way more than that, it is quite loud, almost like a gun going off.
    riojin
    so it's not a burble is more like a full backfire?
    id say it's not sealed properly. those gaskets have to be used tight, and i mean tight!
    Site Supporter Javal's Avatar
    Josho
    Sealant also helps.
    My car did this when i was running it straight out the res..... sounded like a truck, backfired every time i stepped off.
    it's not so much a full backfire cos' there's no flames at all, just a loud "pop" noise. I'll try some sealant and hopefully it cures this, thanks for your help guys. :2thumbs:
    Anthony
    sounds unrelated. check your tps
    what's tps? :blink:
    Senior Member kaibeecee's Avatar
    Pete
    Throttle position sensor
    the TPS runs with the ECU in air fuel mixture
    the TPS setting could be wrong, so there could be excess fuel being left which is burned, which would cause the backfire
    edit: visit here
    It actually sounds like it is a full back fire due to a severe lack of back pressure. ...... But it could be the TPS.
  1. 4AGE popping dipstick
    By Stain in forum Technical - Questions
    Last Post: 27th September 2013, 10:08 AM
  2. t50 popping out of gear
    By sun_moon in forum Technical - Questions
    Last Post: 29th June 2010, 12:04 AM
  3. Popping noise coming from Rear when taking off
    By pkjai in forum Technical - Questions
    Last Post: 17th August 2009, 02:23 PM
  4. Gear popping in and out.
    By djscheppy in forum Technical - Questions
    Last Post: 10th May 2008, 07:03 AM
  5. rear springs keep popping out of spring seat
    By snake in forum Technical - Questions
    Last Post: 14th August 2007, 09:29 PM
