Results 1 to 4 of 4
Thread: Reomving Door Handles
    hey guys
    im installing an ew stereo into my 86 and just wondering how to remove the door handles...
    are they just a circlip (i can't see one ) orisnt simple force to get them off, i dont wanna break anything, thats all...
    cheers!
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    havent had a chance to dismantle my 86 yet, but if it's anything like the corollas it should be two little bolts behind the door cards. take the compllte door card off and see what you can work out
    parrot
    If you mean the arm rest, there are 3 screws underneath some blanking plugs. Pry them out and unscrew.
    If you mean the window winders, there is a clip you pull off by hooking a bit of bent wire over it. Just push in the door card a bit and you should be able to see them. To reinstall, place the clip on the winder and just push it back onto the window mechanism.
    Will
    door handles or window winders?
    door handles is one screw behind the handle, undo that then the recessed plastic bit will come away from the trim when you open the handle and manouver it, the handle stays attached to thedoor frame
    windows, use a rag to work the circlip off the shaft, the open end is in line with the spinny handle
  1. door window trims, door handles
    By Vizz in forum Cars or Parts Wanted
    Last Post: 26th June 2012, 06:53 PM
  2. [QLD] r31 door handles, steering wheel, boss kit
    By Hazer in forum Car Parts For Sale
    Last Post: 22nd August 2011, 11:11 PM
  3. S.A. AE86 exterior door handles x 2
    By markiitourerv in forum Cars or Parts Wanted
    Last Post: 14th August 2011, 03:20 PM
  4. handles mad now
    By DRFTPG in forum AE86 Owners Forums
    Last Post: 25th October 2009, 11:05 AM
  5. Door handle wont open door after changing handles
    By v-tec in forum Technical - Questions
    Last Post: 21st December 2006, 07:55 PM
