yes i have searched. i know the tail shaft has to be changed. but does the brake booster and master cylinder need to be upgraded? if so what should be used to upgrade them? what else needs to be changed?
the brake booster is fine but you need to gut your brake proportioning valve
If your "JDM diff" has disk brakes, you will need the matching hand brake brake cables. And you will need the short hand brake cable that goes to the handbrake lever. Im told you can use one off a SV11 Camry.
If you have disk brake rear, you will want to play with the rear brake limiting valve in the engine bay. It is easiest to open it up and remove the spring and rubber valve to start with.
