Results 1 to 10 of 13
Thread: sliding
    Senior Member darkon's Avatar
    Shawn
    ACT
    Canberra
    my old tires were 205/65r15s on a 6 inch rim
    my new ones are 225/55r16s on an 8 inch rim
    the arse kicks out WAY easier on my new 225s which doesnt make sense to me? is this a sideeffect of having a much stiffer side wall or are the rear tires really worth the next to nothing that I paid for them. I know wit suspension it's usually stiffness vs grip so any light anyone wants to shed would be great
    IMO tyres are the single thing with the biggest impact on handling of a car. If you bought shitty tyres, they wont grip, and you will slide.
    Get some good ones, or if they're going to be drifter (ON TRACK) then find some decent second hand ones.
    Jason
    Broadbeach
    it's actually probably due to a lower profile and tighter fitting tyre, hence there is less tyre squirm.
    Drag cars, big, higher profile tyres for grip
    but yeah, shit tyres would also do the trick
    The profile of the 205/65 is 133mm and 123mm for the 225/55 so not much difference there but I think the stretch will make a difference enough to notice.
    When tires slide, the grip of the tire is mostly dependant on compound so I'm guessing you bought the worst tires money could buy for you.
    Dave
    one idea I just had, was that you now have a much wider tyre so therefore the pressure on the ground is lower
    pressure = force/area
    force = weight of car
    area = tyre width.
    I was reading somewhere, that there becomes a point where a larger tyre surface are, can actually be detrimental to grip because, like above, the actual pressure on the ground drops.
    obviously this is a very crude analysis, and there are a lot more factors involved with "grip", but it was just an idea I had.
    my bet would just be you have crap tyres, if they are 2nd hand, maybe they been sitting somewhere for ages and have gone hard and buggered.
    - Blaise Pascal
    Will
    cheap shit tyres don't grip, if they did then the universe would be all topsy turvey
    no offence ke70dave
    Elite rthy's Avatar
    Leo
    Tulla
    yeah I use to buy cheap pov pack 185/60/r14 rwc $10 tyres for my 1st ae86 and wondered y I spin out all the time...
    now using goodyear grid 195/50/r15 tyres that stick in the wet
    Dave
    where did you get that quote from? it's not in my reply there???? :blink:
    I know cheap tyres don't grip, if they did, like you said, the world would be silly
    edit: yeah I get what you've done, very cunning and smart, yeah ill agree it was a bit bla bla bla-ish lol
    - Blaise Pascal
    Shawn
    ACT
    Canberra
    I was actually thinking that myself. also I was thinking less pressure on the tire could mean improved tread wear. is it just me or have we solved the age old question of "if drifting's about sliding why do d1 drivers have rediculously large tires on the rear but small ones on the front" lol
    and yes I'm pretty sure they'v been sitting around getting old and buggered.. I mean the tread has cracks in it lol if you see me round il probably be taking advantage of my crappy tires and rippin skids
    Don't put much faith in the "derivation" above. Tyre grip and wear depend on a huge number of factors that aren't particularly well understood (Google "pacjeka magic tyre model" and have a read).
    You have shit tyres. They will slide.
    The stiffer, smaller sidewall should help the situation. However refer to the above again.
  1. Crazy jap eats macca's while sliding! Only in Japan
    By bams_keto in forum The Drift Channel
    Last Post: 9th July 2010, 04:20 PM
  2. Ruf Porsche sliding 'round the 'Ring
    By all torque in forum Offtopic Discussions
    Last Post: 31st January 2009, 02:23 AM
  3. sweet street sliding
    By keto 4122 in forum Toyotas in the Media
    Last Post: 18th November 2007, 04:40 PM
