It will be fine![]()
Yeah as topic..
My car is a AE86,my front wheel is 15'' with 8'' running with 195/50 with no issue so will a 205/50 will fit ok?..or is it a good idea??
not enough info dumass
yes it will fit the rim fine, but if you are borderline for scrubbing on the guards/struts/everything then it might rub more.
do your current tyres rub on anything? what offset are your wheels?
195/50 would look pretty cool on an 8 inch rim!
thanx for the inof all you KE/AE lovers
As for the tyres rub anything, offset on the wheels I really don't know because the car is still in japan waiting to get shipped.
Here some photo's of my car so would have good idea of it(Rear wheel is 9'' with 195/50)...I'm planing to run 205/50 all round
As see the last Photo do you guys think I should go for ???/55/15 for the car being a bit too low??
Thanx again!!
nah don't go 55, the 205 50s will be on the big side alread, and the ride height of that car is pretty high already. I run 195/50s and it looks fine, but mine is al ot lower than that
Thanx for the fast Reply RoadSailing,Cool I just want someone to say what you just have said. I want to go 205 because Proxes RA-1 only come in 205/50 for 15'' wheels.
I'm using 205/50/15 also on my ae86, no problems and sits pretty low
awang...how wide is your the wheels? 7''?8''?9''?
if is 9'' do you have any drama fitting a 205 on the wheels?
it's 7, sorry I didn't mention it earlier
dude, as I said in the last thread you made, 205's are fine....
