Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: 16v big cams
    Stefan
    Parkinson
    hi I'm rebuilding my motor am going to go na banger
    cams I was wanting good responsive power so cam deg 304 8.5 mm lift
    or a 288 deg with a 9mm lift
    want it reasonably streetable also running quads and microtech ecu and 4.1 kg fly wheel
    what are your ideas??????????
    Jonathan
    A very basic rule of thumb has been: the greater the duration, the higher the rpm where max power will be made. The greater the lift the more torque. But a engine is very dynamic and weird things happen.
    If I was going to rev it to 8500rpm I would go the bigger duration. But I don't have much experience with this.
    grassworkzgarage
    how bigs ya buget cause higher the lift means valve train work will need to be done to handle it cbf going into it but you change one thing then you need to changge another thing & so on & so on
    it aint as easy as putting in some 304 bump sticks and off you go ...... I wish lol
    Senior Member kaibeecee's Avatar
    Pete
    ^ in other words he's saying if you go to a higher duration (to be safe say past 264in or ex) you'll need a valve lift kit, get bigger shims
    Coolangatta
    ...and you may need shim under bucket, or shimless buckets if you're looking to increase the lift. Throwing a shim at high revs will be a costly experience.
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    It's an oxymoron
    Jul 2009
    Kane
    Coburg
    just get mine man
    straight bolt in no mods
    Stefan
    Parkinson
    what is the lift on your cams kane?
    Jul 2009
    Kane
    Coburg
    8 I beleive
    maybe 7. something
    but you don't have to change any shims.. maybe valve springs but thats it.
    Senior Member awang's Avatar
    Zul
    Brunei
    Stone City
    Brunei
    any camshafts with 9.0mm of lift and above require valve train kit
    correct me if I'm wrong
  1. 4AGE 20V big cams + Adjustable cam gear
    By luke111 in forum Car Parts For Sale
    Last Post: 18th September 2012, 10:17 PM
  2. Big port cams into 4agze
    By ae86 slide in forum Technical - Questions
    Last Post: 15th April 2010, 01:35 PM
  3. big port cams
    By .ady in forum Cars or Parts Wanted
    Last Post: 7th December 2009, 08:09 PM
  4. wtb.. big port cams
    By baka_ae86 in forum Cars or Parts Wanted
    Last Post: 3rd June 2007, 12:00 AM
  5. Big Cams, Bigport Quadthrottle Adaptor, Cam Wheels
    By jctwincam in forum Car Parts For Sale
    Last Post: 21st March 2007, 10:42 PM
