^^^^^ so how much roughly does a GZE put out standard? if it is already running with in a AE82 then will it run in my keto with the fuel pump and what not?
my jdm t50 held up for about a year in my drift car gze with pulley kit. josh young was driving a 145rwkw 86 with a t5o box at eastern creek!!
the fuel system from your ke70 won't work.... the fuel pump runs off the motor, if the fuel lines are the same as ae86 thne you can run the stock lines but will need a efi fuel pump... not sure on power do a search
clinton i would go a w58 or w57 or something, you arnt exactly kind to your car i mean you managed to root a 4kc hahaha
all depends on your driving style mate, some ppl break t50's on bigports becuase they drive "uber agressively", other ppl have great success with a T50 behind a 150kw monster, because they treat it nice and gentle, if you are the first kind, get a W box, if you are the 2nd, you should be right with a t50
judging by SON57A's commnet, better get a w box
- Blaise Pascal
id definately rather be using my t box hearing the noises coming from my damn expensive w box!!! still holds together and shifts fine tho.
