what size do you want?
what application do you want them for?
Does any one know any other kind of injectos that fit a 4age motor ive been told magna injectors fit is this true?
my engine didn't come with injectors so i want injectors that are easy to find.
i have a set of 4age injectors if you need em
How much and where do you live.
Hey mate, one of my mates put in smallport injectors into his bigport.. you just need the plugs so you can wire it into the loom, said it made a noticable differance.
otherwise gze ones should fit i would say... not sure on 20v ones, wouldn't have a clue.
Also 7mgte ones that are like 440cc i have heard fit
No, no , no! Smallport injectors are high resistance, bigport injectors are low resistance. You have to match the injector resistance to suit whichever ECU you are using. There are lots and lots of top feed injectors with varying flow rates and impedence that will fit from various manufacturers.
GZE injectors are low resistance and top feed but the flow rate is way to high for the standard ECU. A waste of time money and petrol. 20 valve are side feed so won't fit the standard fuel rail.
You have to bear in mind the limitations of the fuel map within the standard ECU. If you have an aftermarket ECU the rules change of course. The injector plugs are a minor inconvenience.
Just pick up a set of standard grey, blue or pink 4AGE corolla units, assuming you are running a standard ECU.
20v are side feed, tottaly incompatable
whats a bigger injector u can put in 20v sam?? want a small upgrade
-Get 440cc 1JZ/2JZ turbo injectors for a direct fit on a 20V
-7MGTE 440CC are a direct fit for a 4AGE bigport/smallport
If the injectors are low impedance, keep the resister pack, if they're high impedance remove it from the harness.
