Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: 4age injectors
  1. #21
    parrot
    I have read somwhere that some ECU's incorporate the resistors in some form thus removing the need for an external resistor but I am VERY uncertain of that.
  2. #22
    Oldschool Member
    Jul 2006
    Yep, that's what I'm starting to think is the explanation.
    I'll track down my AE82 twinky ecu and compare the part no's to the one that came with a resister pack attached. I've always wondered what the deal was with this.
  3. #23
    Oldschool Member
    Aug 2005
    <div class='quotetop'>QUOTE (beerhead @ Aug 13 2007, 11:56 PM) </div>
    Sorry to dig up an old post...lol
    I have been searching, and need to know and answer on this please...
    My situation....:
    4age, N/A, quads, 288/304 cams, power fc (so similar to std comp), expecting about 180+ hp
    I need bigger injectors, and was thinking around 300cc, 7MGE are around this size,...
    Questions:
    Are these injectors compatible, (ie low impedance??)
    If not suggest some alternatives...
    Regards
    Scott
  4. #24
    Ok
    Seamus
    Milton
    Bigport injectors are low impedence, so you can use:
    yellow (7MGE) 295cc injectors
    orange/maroon (GZE) 365cc injectors
    black (7MGTE) 440cc injectors
    if the injectors ARENT that colour, they might be out of a later model engine that could be high impedence, so be careful
    ^ Clicky clicky!
  5. #25
    Oldschool Member
    Aug 2005
    Thanks Seamus...
    Time to go shopping I guess lol
    Regards
    Scott
  6. #26
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    i have a bigport, so if i get 4 yellow 7mge injectors it would be a small performance upgrade
    ~KEEP DRIFTING FUN~
  7. #27
    Ok
    Seamus
    Milton
    no, it will just run rich as piss and foul plugs + make less power
    if you have supporting mods (cams, intake, exhaust, etc) and a computer to tune it, then yes, good idea
    ^ Clicky clicky!
  8. #28
    Jonathan
    You should be able to check the resistance of the injectors you have, with a multimeter set to resistance. Although that may not give you the total impedence... Maybe you could delete the resister pack, or add one, depending on application. This is something to think about...
    But there is often enough injector options so you don't need to change your resister pack setup.
    There are lots of injector lists about, many listing resistance and flow rate.
  1. Replies: 2
    Last Post: 2nd September 2012, 08:44 PM
  2. 4AGE Injectors
    By cbjaust in forum Technical - Questions
    Last Post: 7th May 2010, 01:45 PM
  3. 4age injectors HELP PLEASE!!!
    By mick in forum Technical - Questions
    Last Post: 5th May 2009, 12:06 AM
  4. 4AGE Injectors
    By Stain in forum Technical - Questions
    Last Post: 24th January 2009, 06:22 PM
  5. 4AGE injectors
    By Hachi Roku in forum Technical - Questions
    Last Post: 5th May 2006, 10:24 PM
