Results 1 to 10 of 15
Thread: rear springs keep popping out of spring seat
    Jim
    West
    hey ppl...
    i chopped my rear ajps (5kg/mm) springs yesterday, by one coil, running sierra shoxs.( only temporary ) i like the hieght and stiffness, feels good, but after pulling sum sik skidz the last coil keep leaving the spring seat....any ideas on how to keep it in?? maybe a bit of rubber other than the standard ones? on maybe nothing at all?
    cheers in advance for any sugestion...
    Ferny Grove
    i always had this as well
    using falcon springs though, i was able to flip them upside down and it stopped
    you might be able to do it with your 86 specific items
    Veteran deleta's Avatar
    Callum
    Queensland
    Wynnum
    Or Gilly could say it 1st lol
    "try flipping them so the flat part of the spring is on the diff, this is what i do with my "lowered" falcon springs. it works very very well " :2thumbs:
    Jim
    West
    hmm i dunno if it will work... but ill giv it a go...
    any idea on the spring rate of the falcon springs??
    Feb 2007
    I'm running falcon's too. just flip them upside down so the cut side is pointing up into the car. they wont fall out then.
    I think falcon's are 6.5kg/mm.. ?? but i'm not sure, i'd like to know the answer too.
    Ryan
    qld
    brisbane
    Aust.
    im also keen to know their stiffness.. my car is like a rock. very unforgiving on bumps.
    Senior Member Brenton 86's Avatar
    Brenton
    Used to happen to me when i was running choppers, i drilled holes in the spring seat and zip tied the bases in. It worked, just be carefull where you thread through the zip tie.. too low and the coil above will flatten and break the tie.
    ADM 4AGZE SPRINTER
    JDM SR20DET TRUENO COUPE
    ae86s love since 2004
    Rob
    i cut some lovells in my rear, same problem...
    goto anyone with an oxy, heat up half a coil on the cut end, bend it in to make a flat base, cost me $10 to use the oxy (as i dont have my own oxy....) mind you no one will agree to do it for you as its mega dodge, so just get someone you already know to let u use their oxy...
    so far so good, havent poped out since
    Veteran Konakid's Avatar
    Henry
    Eastern
    Definately not anywhere near that stiff, id say falcons in the rear are about 4kg depending on how chopped they are. Then it depends if they are the stiffer falcons from a bigger model, e.g LTD version.
    Cut bit pointing up, always, they'll be fine especially with sierras.
    Jim
    West
    ok thanks peeps ill giv it a go and let you all know :2thumbs:
  1. Wtb Rear Bc 6kg 160mm spring and seat perch ajustment
    By timpy in forum Cars or Parts Wanted
    Last Post: 11th June 2012, 08:20 PM
  2. Replies: 0
    Last Post: 8th December 2011, 04:28 PM
  3. ajps rear spring seat adjusters
    By ke_70 in forum Car Parts For Sale
    Last Post: 7th December 2010, 08:01 PM
  4. Rear spring Rubber Seat thingys
    By sly1300 in forum Cars or Parts Wanted
    Last Post: 10th April 2009, 11:20 PM
  5. WTB: 7kg rear springs & coilovers helper spring kit (1 pair)
    By xcedricx in forum Cars or Parts Wanted
    Last Post: 16th September 2007, 02:01 PM
